Ignition fuse location, nothing turns on
Re: Ignition fuse location, nothing turns on
27 Jun 2015 15:26Jrider wrote: The horns are both working now with a 30amp fuse. This is the fuse that is in the 83 and later GPZ. But I think for the long run I will install a relay so it doesn't surprise me in the middle of nowhere. Thanks guys.
Bad idea; I would highly recommend you take the 30 amp fuse out and replace it with the correct fuse. Fuses are sized to protect the wiring. A 30 amp fuse will not protect wiring that is sized for a max of 20 amps. So if by increasing the fuse capacity you exceed the 20 amp threshold on wiring sized for 20 amps you can set the wires on fire. Replacing a burned harness, or worse a burned bike, is much more trouble than unplugging one horn until you can install the proper circuitry. Ed
The following user(s) said Thank You: Jrider
- Jrider
27 Jun 2015 17:05
Duly noted.
1982 Kawasaki KZ 750 R , Stock
2007 Harley Davidson Police Electraglide
27 Jun 2015 18:47Jrider wrote: Thanks, TexasKZ. I will try to duplicate that set up. I am not an electrical whiz, but I can follow instructions. Any more detail you can provide will be helpful. Will all the horn wiring be apparent when I lift the tank?
The diagram in the fsm will be invaluable for tracing the circuit. Making sure the stock setup is working as it should is the first order of business, since parts of it are needed for the second horn. If I had a schematic or even a drawing on a napkin, I'd be happy to share it, but alas I do not. 650Ed or loudvx would probably be your best source of details. Ed is actually running such a setup and Lou has forgotten more about electricity than I will ever know.
- Jrider
28 Jun 2015 09:02
Thanks guys I will use the methods diagrammed by ED and explained by swest. I will print out Ed's diagram.
28 Jun 2015 13:51
Good man.
