After market speedo or tachometer
  • missionkz
  • missionkz's Avatar Topic Author
10 Jun 2015 01:55
#675962
Has any one any experience with the after market speedos and tachs I see all over the net for anywhere from $160 to $180 each?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • martin_csr
  • martin_csr's Avatar
Re: After market speedo or tachometer
10 Jun 2015 05:12
#675970
Can you post a link or two of what you've seen? Are they mechanical or electronic?
No first hand experience, but for a mechanical drive speedometer you'll need to get one that says something about being 2240 which indicates the ratio --- I think all Japanese bikes use that. Others may say 2:1 or 1:1. The speedo on my 81 650 says 2240 revs = 1 mile on the back & I did the math for a number of models for comparison.
  • TexasKZ
  • TexasKZ's Avatar
10 Jun 2015 17:30
#676074
  • missionkz
11 Jun 2015 11:32
#676172
I might be the one doing the test then.... Got to ride a few buddies new bikes this week in a 120 mile trip we took.... and the difference in accuracy and stability of those modern instruments and my 37 year old NDs... **GASP** LOL!!
Bruce
1977 KZ1000A1
  • Gordy
  • Gordy's Avatar
11 Jun 2015 16:04
#676207
missionkz wrote: Has any one any experience with the after market speedos and tachs I see all over the net for anywhere from $160 to $180 each?
I've got a koso DB-01r on my z650. So far I've been impressed. It's much more compact than the stock gauges. You can get them with all kinds of different speed sensor options too. My thread over in projects has some pics of it if you need them.
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Jun 2015 16:10
#676209
Do you mean the stock replacement ones from z1partsinc etc?
  • missionkz
16 Jun 2015 14:42
#676841
swest wrote: Do you mean the stock replacement ones from z1partsinc etc?
Sorry Steve I missed seeing this question... pretty much yes. I'm tired of R&R'ing these gauges and after three separate loops on both, including peeling back those damnable compression rings, I'm still not satisfied.
I was thinking I could have bought an aftermarket speedo or tach and been feeling done with this part of the restoration.
Bruce
1977 KZ1000A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Jun 2015 16:03
#676855
I'm with you. I'll but a speedo when I can afford it, (other things more important) then get a new Tach. Mine looks good, it works but for some reason it won't go down to zero with the cable on. I'll put my old ones on eBay "parts or not working" Let someone else F with them.
