Speedo Electric drive swap with mechanical KZ1100
  • eric951turbo2
  • eric951turbo2's Avatar Topic Author
08 Jun 2015 13:22
#675748
Hey guys, first post here.
I'm rebuilding a 1982 Kz1100 A2 shaft. I already purchased a mini mechanical speedometer. To my surprise, when I started the installation, I noticed that my actual drive was electronically driven.
If I find a speedometer drive with the cable from a 1983 KZ1100 (same front wheel size), will it be direct fit???
I can't seem to find my answer anywhere on the web... The graphic on the partzilla site isn't really clear on that.
NEW UPDATED... I just got a call from a salvage shop and they say they have a speedo drive from a kz750 (between 82 and 84).... will that work?
KZ1100 A2 : In progress
KZ750 Spectre : Ugly but runs
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Speedo Electric drive swap with mechanical KZ1100
08 Jun 2015 13:25
#675750
Worth a shot.
  • eric951turbo2
08 Jun 2015 13:46
#675752
Ok, I'll drive up there tomorrow with my wheel assembly and check if it's a match. Looks like it on partzilla. I'll post back in a couple of days with the result.
  • eric951turbo2
12 Jun 2015 07:13
#676278
Ok so I found a mechanical speedo drive and cable from a KZ750 1983. The speedo drive was direct bolt-on replacement with the original electronic drive...
Spinned the wheel and everything works.
So the answer is yes, it works
