Speedo Bounce
- ffltstn
Speedo Bounce
08 Jun 2015 10:46 - 08 Jun 2015 10:46
On my '82 KZ1000 with electrical gauges At times , and it seems like after i get on it hard, the Speedo will bounce around some. maybe about
- 5 mph for a few secs. Anyone seen this issue? Is it in the gauge,the wiring, the pickup at the wheel? It's not a major issue but it may be some day so hoping to fix it now.
Thanks,
Ken
- 5 mph for a few secs. Anyone seen this issue? Is it in the gauge,the wiring, the pickup at the wheel? It's not a major issue but it may be some day so hoping to fix it now.Thanks,
Ken
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
'95 Voyager XII
'98 Vulcan 750
Last edit: 08 Jun 2015 10:46 by ffltstn.
- 80B4
Re: Speedo Bounce
09 Jun 2015 06:11
I have had that problem and it turned out to be a bad ground. After I cleaned the ground cable and wires the bounce was gone.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- ffltstn
Re: Speedo Bounce
09 Jun 2015 06:52
Ok thanks I'll check into that. I need to replace a bulb in that gauge anyway.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
'95 Voyager XII
'98 Vulcan 750
Re: Speedo Bounce
09 Jun 2015 07:18
I replaced my bulbs with LED's. You can't buy ones that last anymore.
- Bama704
Re: Speedo Bounce
09 Jun 2015 08:57
Steve, where did you find led bulbs for the gages? Are they also the same bulbs for the neutral light etc...?
1977 KZ900
Carbs are late model 1975 28mm
Re: Speedo Bounce
09 Jun 2015 10:38
I got mine on eBay. I bought the $5 ones just to see how they worked. They are all the same so 10 for $5 free shipping was a good deal. One came apart as I was putting it in. They asked if I'm satisfied and could I leave good feed back. I told them about the bulb so they sent me two more. I gave good feed back with what happened. They're still working but I would buy the more expensive ones and will if these fail. Brighter than the old ones, draw less power and should last a good long time.
- Jonny
- woot!
Re: Speedo Bounce
09 Jun 2015 10:51
I had good luck with products from Superbrightleds.com (Think that's right)
No affiliation, but their selection was pretty huge, and you can select narrow/wide angle in the small P type instrument lights. I think you pay a little more than with some of the direct from China importers, but it might be worth it. Other more common bulbs like the 1157's for turn signals give you an even broader range by way of number of LEDs per, color, angle etc...
I swapped out all the old bubs on my bike with LED to take a little bit of load off the charging system. I run a DYNA, and have never had any problem with keeping a battery charged, but taking even a little bit of load off seems like a good idea.
Cheers,
Jon
Cheers,
Jon
'78 KZ 650C2 'Lila'
'71 Norton Commando 750 'Eadie'
St. Catharines, ON (Mostly, anyway...)
Re: Speedo Bounce
09 Jun 2015 11:01
That's what I'm doing. I have a volt meter. With the head light off, I'm at 14v. Head light on 13v but while running it will creep up to 14. Head light and running lights, a lot, it goes down to 11 and creeps back up eventually. I also have a Dyna S and 3 ohm coils.
- Bama704
Re: Speedo Bounce
09 Jun 2015 12:21
Ok cool, I was taking a look at the superbrightled.com site as well.
www.superbrightleds.com/moreinfo/ba9s-ba...led/6/#/tab/Overview
Looks like this is what I will be buying.
1977 KZ900
- ffltstn
Re: Speedo Bounce
09 Jun 2015 16:38
These LED bulb will replace both bulbs in both gauges? I have had them apart and they are different voltage but i think they are the same actual size.
'82 KZ1000
'95 Voyager XII
'98 Vulcan 750
'95 Voyager XII
'98 Vulcan 750
- Jonny
- woot!
Re: Speedo Bounce
10 Jun 2015 19:28
Yup.
It's the same type for all 4 of the bulbs in your instrument cluster. I didn't check what the voltage on that circuit was, but it shouldn't make a difference. I don't recall precisely what was written on the bulbs, as it's been a while since I installed them, but they are rated for something like 9-14V. So, in any case they accept a bit of a range in voltage.
I imagine those 4LED bulbs will be good. I bought the cheapy singles, but I can attest that even they made a pretty big difference. Originally, I could hardly see the lights on the central cluster on a bright day. Now when I turn the bike on, it is perfectly clear that I am in neutral etc.... The bulbs in the speed and tach also made a world of difference, especially considering they light indirectly, having a brighter bulb in there makes seeing them at night a breeze, where before I could sometimes barely read them between street lights. Drawing a wee bit less power is just an added bonus after that.
Cheers,
Jon
Cheers,
Jon
'78 KZ 650C2 'Lila'
- Jonny
- woot!
Re: Speedo Bounce
12 Jun 2015 07:55
Just a quick FYI for anyone who was interested.
Got some email from superbrightleds today. They are running a bit of a sale it seems. Use the code DAD15 at checkout for 15% off your purchase should you choose to make one. I almost wish I needed some bulbs now, but such is not the case.
'78 KZ 650C2 'Lila'
