Sealed beam conversion 82 550
  • apbling
  • apbling's Avatar Topic Author
03 Jun 2015 07:52
#675095
So, I was thinking I'd like to switch from the sealed beam headlight to a halogen bulb with the help of a conversion kit. Z1 has them, but they look out of stock for the time being. I did an ebay and amazon check and they are significantly more expensive. Anyone snag one of these 7" kits from a different website for a reasonable price?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Sealed beam conversion 82 550
03 Jun 2015 08:04
#675100
What kit? I put a halogen sealed beam from OR in the 550 and put it's good one in my Z1.
  • apbling
03 Jun 2015 08:29
#675110
OR - you mean o'reilly auto?
I did see the silverstar sealed beam headlamps - just thought it'd be nice to get this kit:
www.z1enterprises.com/ItemDetails.aspx?i...bulb&item=EM66-75806
and then have some options with different bulbs.
  • missionkz
  • missionkz's Avatar
03 Jun 2015 11:13 - 03 Jun 2015 11:14
#675123
The Z1 seems to be the best price....
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 03 Jun 2015 11:14 by missionkz.
  • 80B4
  • 80B4's Avatar
03 Jun 2015 11:44
#675128
Mikes XS sells a good ones PN 09-0051 and 09-0072 for under $38.00.
www.mikesxs.net/products-77.html#products
1980B4 1000
1978 Z1R
1978 B3 750
03 Jun 2015 12:32
#675134
Here's the Halogen sealed beam lamp I use. It works very well, is very bright, and because the wattage is 35/60 the low beam never taxes the bike's electrical system even though it is bright. Ed
www.summitracing.com/parts/WAG-H6024/
  • martin_csr
  • martin_csr's Avatar
03 Jun 2015 14:44 - 04 Jun 2015 06:13
#675142
It probably is a sealed beam, but the diagrams for the 550-C3 show a halogen bulb.
The 80-81 had the sealed beam, so it's possible your 82 does as well.
A conversion option is to get the headlight from an 750-4 & probably whatever other models had a halogen bulb.
The stuff from an 82 750-Ltd was an easy direct swap onto my 81 650-CSR (Lens unit, dust cover & H4 bulb).
The lens was cloudy, so I cleaned it with denatured alcohol.
Last edit: 04 Jun 2015 06:13 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Jun 2015 20:39
#675169
I have the Wagners in my 69 F 250. I borrowed one until I got a new one. When I got the 84 550, I stole it out of it and put in in my Z1. At least Bossie got something out of the deal.
  • apbling
04 Jun 2015 10:38
#675218
I agree martin, the diagrams and dennis kirk etc say H4, but I'm almost 100% sure its sealed beam.
