1977 KZ650, switch to stock CDI?
- rrsmsw9999
03 Jun 2015 04:57
Hello all, I had a buddy send me a stock KZ1000 igniter, advancer and pickups. The whole thing is there, but the backing plate and advancer are slightly different sizes. Can this be used on a KZ650? And even better should it? If it can is there a good wiring write up somewhere? I am not having point problems or ignition problems of any kind. Would like to not have point maintenance but not willing to "experiment". What say ye?
R
R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
- mike1957
Re: 1977 KZ650, switch to stock CDI?
03 Jun 2015 05:13
You know the old saying --If it ain't broke don't fix it.You can look up
part numbers to see if they match up. Here's the link
www.rockymountainatvmc.com/oem-parts
mike1957
03 Jun 2015 05:20 - 03 Jun 2015 05:21
My initial gut reaction is that it probably won't work --- the timing advancer's advance curve would be wrong for the 650 & the pulsing coil plate probably won't fit. I believe loudhvx said the pickups are interchangeable, so I think they can be used on a 650 plate.
PS: I don't think the Kawasaki electronic ignition is a CDI. not sure.
Last edit: 03 Jun 2015 05:21 by martin_csr.
03 Jun 2015 07:06
I'd go Dyna S instead.
03 Jun 2015 08:08
As mike1957 said "if it ain't broke don't fix it."
More to the point - if it ain't broke don't BREAK it! Ed
The following user(s) said Thank You: missionkz
03 Jun 2015 08:10
:woohoo:
- rrsmsw9999
03 Jun 2015 09:43
Anyone need a KZ1000 electronic ignition? :woohoo: R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
Crashed 6/2016
1980 KZ550A
Sold 3/2016
03 Jun 2015 11:02martin_csr wrote: PS: I don't think the Kawasaki electronic ignition is a CDI. not sure.
You are correct. CDI's are found on dirt bikes, not KZ's.
- loudhvx
03 Jun 2015 12:45
I think Rstnick put a 1000 system onto a 650. But I'm not sure if he used the 650 advancer or the 1000. He just cut down the timing plate (he has those crazy locksmith skills).
You would need the 2.3 ohm coils, though, too. The points coils won't really work well with the Kz electronic system.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
