How do I wire up a universal tail light.
- Waynecarpenter
02 Jun 2015 18:31
Bike is a 1982 kz750 e3
Bikes rear brake light switch is the only thing I want to hook up to the light. Front brake will not be needed. So rear brake light switch has 2 wires. One blue and one brown. See pic. My universal light has 3 wires. One yellow, one green, and one brown. See pic. So what do I have connect to make this work? Thanks for any advice.
Attachment ImageUploadedByTapatalk1433294421.742485.jpg not found
Attachment ImageUploadedByTapatalk1433294441.118968.jpg not found
Attachment ImageUploadedByTapatalk1433294451.774298.jpg not found
- DobbinsCMA
Re: How do I wire up a universal tail light.
02 Jun 2015 21:01
Green to blue, brown to brown and yellow to nothing.
'80 Kz1000B4
MTC 1075 .375 webcams Mikuni RS34
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
- Richardb98
03 Jun 2015 08:25
hey where did you get that one it looks nifty. and more importantly how much did you drop for it?
- TheForumTroll
03 Jun 2015 08:48
Looks like a Highway Hawk to me.
-[ KZ700-A1 '84 ]-
- Waynecarpenter
Re: Re:How do I wire up a universal tail light.
07 Jun 2015 17:58
Got it off eBay for like 10 bucks
- Waynecarpenter
07 Jun 2015 18:15DobbinsCMA wrote: Green to blue, brown to brown and yellow to nothing.
Are you sure? I tried this and nothing happened. Maybe another ground is bad?
- StreetfighterKz
07 Jun 2015 18:33
The brown and blue wires in the first pic are for the brake light switch. The brown is constant power to the switch. The blue wire leaves the brake switch and travels to the rear of the bike. There should be a 5 or 7 wire harness that runs back to the rear of the bike. Three of those wires should be connected to the brake/tail light.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Waynecarpenter
07 Jun 2015 18:56
My harness when I received it was modified multiple times. Some good some bad. Bike runs very well tho. Wiring just seems a little sloppy. Wanting to add a tail light at this point. The harness is wrapped up so the wires may be in there. I was able to easily unwrap the two switch wires. Should I unwrap more of the harness or work with what I got so far? I feel like I have a very good connection with the wires that were suggested to connect but still no light. What gives?
- Waynecarpenter
07 Jun 2015 19:18
What is the black wire? Seems to have had something wires to it but pulled apart.
Attachment ImageUploadedByTapatalk1433729270.732590.jpg not found
- StreetfighterKz
07 Jun 2015 20:09Waynecarpenter wrote: . The harness is wrapped up so the wires may be in there. I was able to easily unwrap the two switch wires. Should I unwrap more of the harness or work with what I got so far?
You cannot hook the brown or blue wires for the brake light switch to the taillight and get it to work.
If the harness is in really bad shape, you might as well unwrap the harness. I would start at the blue wire from the rear brake light switch and follow it. You should end up at a splice in the main harness. One direction will go toward the front to the front brake light switch the other will head toward the tail light area.
My suggestion to you is to get a service manual if you don't have one already or at least a wiring diagram, and study it. If you really are doing a bare bones harness, unwrap the harness and strip out what wires you aren't using and fix what you are using said manual or diagram.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- MFolks
08 Jun 2015 09:23
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
HEADLIGHT
- DobbinsCMA
08 Jun 2015 11:19
Ya sorry man. I just guessed because no one had answered it at the time and I hoped my answer would bump it. Great list Mforks
'80 Kz1000B4
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
KZ440 Project
81'KZ750E2 Project
Past- '81 Kz750H
