79 kz650 runs good then starts missing terribly
  • bikerdave79
  • bikerdave79's Avatar Topic Author
Re: Re:79 kz650 runs good then starts missing terribly
18 May 2015 18:32
#672674
Here's what the points are doing
  • bikerdave79
19 May 2015 04:52
#672700
New coil is on order. I guess we'll see what happens. I'm hoping the excessive arcing is due to the poorly firing coil
  • LineArtist
  • LineArtist's Avatar
19 May 2015 18:56
#672788
Does just putting a new spark plug in the #2 make the problem go away for 100-200 miles until it fouls again?
I'll go by what you said about the valve clearances being in check. Make sure you get a read on the secondary of the coil (pull the caps off the wires and remove the coil wires from the harness). The plug caps carry resistant and should also be replaced.
Have you done a carb sync?
'79 KZ650B3 (stock)
'79 KZ650B3 (parts bike)
'06 HD 883R
  • bikerdave79
19 May 2015 19:26
#672794
Yes to carb synch. The plug did not refoul. But I didn't run it long because the coil breaks up when hot. The coil caps prove out resistance wise. I think the coil just gave up the ghost.
  • bountyhunter
  • bountyhunter's Avatar
Re: 79 kz650 runs good then starts missing terribly
20 May 2015 00:33 - 20 May 2015 00:33
#672819
Coil is always the first suspect. The "coil" is actually a flyback transformer which is subject to the trifecta of what kills electronic devices: excessive heat, high voltage stress, and vibration. Plus it sits under the tank where it doesn't get any airflow.
Last edit: 20 May 2015 00:33 by bountyhunter.
  • bikerdave79
21 May 2015 06:29
#672963
New one should be here by Saturday. I'll let you know what happens
  • bikerdave79
22 May 2015 18:26
#673222
Well coil didn't fix the issue but I was able to figure it out. I had a feeling the excessive arcing in the 2-3 point meant something so I substituted the old condensor set back in to see what happens. Arcing gone, and bike runs like a dream. So it seems my 2-3 condenser was DOA out of the box. Grrr lots of time and aggravation wasted on cheap faulty parts...
  • missionkz
  • missionkz's Avatar
22 May 2015 23:06
#673251
That's great.... all capacitors loose it eventually.
Before figuring out my coil was going bad, I installed my old points plate, etc.
My 2&3 points were arcing a bit and I connected my high end ($$) digital capacitor tester to the two caps one at a time.
One read .26uF while the other read .099uF.
That was at 100Hz (which would be sort of like 6,000 rpm) and that is 68% less the other one.
Guess which one was having much much more of the arcing sparking? LOL!
I actually was a bit surprised by that because the bike actually ran quite well, regardless, with the two new coils, my homemade ballast resistor and two old points with a leaky capacitor.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • bikerdave79
23 May 2015 21:00
#673414
Put quite a few miles on it today. So far so good!
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2015 21:08
#673418
Back in the day I used Ford F series condensers when mine went bad. No Kawasaki shops around.
  • bikerdave79
25 May 2015 16:46
#673703
I put 140 miles on the bike today without so much as a hiccup. I'm just going to leave the old condensers in there since they seem to be working just fine. Thanks for all your help guys
