blue wire behind cover where starter goes..
  • kzrob
  • kzrob's Avatar Topic Author
Re: blue wire behind cover where starter goes..
07 May 2015 16:18
#671058
All the three are there..oil light works.what does neutral switch do? Light comes on in nuetral
  • kzrob
07 May 2015 16:23
#671059
One more thing ..when trying to start starter relay clicks..could the starter cause the starter switch "off/run/off" to not work?
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 May 2015 18:06
#671073
You shouldn't get anything with the kill switch off. Looks like that wire was a add on by the PO.
The following user(s) said Thank You: kzrob
  • kzrob
07 May 2015 18:11 - 07 May 2015 18:13
#671074
No no Steve..with it in run it clicks ..before I figured out starter was bad..when pushing run with button pressed
Last edit: 07 May 2015 18:13 by kzrob. Reason: more to say
  • kzrob
07 May 2015 18:15
#671075
I'm thinking it was add on after all of these helpful suggestions..THIS IS GREAT HELP..
  • kzrob
07 May 2015 18:22 - 07 May 2015 18:24
#671078
Also waiting on air pods..since it was down because of starter..I figured what the heck..I had 82 kz 550 ltd that was chain drive that had'em..I liked that look.
Last edit: 07 May 2015 18:24 by kzrob.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 May 2015 18:43
#671081
You'll be busy for a while. :lol:
  • kzrob
07 May 2015 19:04
#671082
Nah..carburetor guy I got..just got to get it running long enough to get it to him..he doesn't have a trailer and I don't either..so one step at a time..the 82 I had ran great on pods,but at same time..don't know what was adjusted either.. who knows
  • kzrob
07 May 2015 19:16
#671083
Appreciate all the help fellas.. anything you might be able to give advice on just yell..I'll check daily..
  • Tyrell Corp
  • Tyrell Corp's Avatar
08 May 2015 11:25 - 08 May 2015 11:33
#671132
The clicking you hear is the solenoid relay closing, so your start button is energising the relay as it should. If you bridge the solenoid terminals with a screwdriver and the starter motor turns then the fault is most likely your battery / solenoid / starter / frame earth connections.
TEST Make sure your battery is fully charged and servicable, and the connections are clean and tight. Get a pair of car jump leads, connect the battery - to a good ground anywhere on the engine, and repeat the above test. If sorted your problem is your - battery to motor ground. If not then go from battery + to starter solenoid, test , then try from other solenoid terminal to starter motor terminal (careful here, don't touch anything with the jump lead but the starter motor terminal).
This diagnostic will likely trace your problem to either soleniod or either of the three battery cables. That is one - , battery to engine ground, and two + from battery to solenoid, and solenoid to starter motor. Either clean up the terminals and connection points or replace the cable(s) complete.
If that doesn't fix it then look to your starter motor brushes, but as 550 starters seem to last forever and they are easily available very cheap probably just find a replacement.
That blue wire seems a red herring, just test it though as if it goes live and grounds it will blow a fuse.
Last edit: 08 May 2015 11:33 by Tyrell Corp.
  • kzrob
08 May 2015 14:45
#671158
Got it tested..turned out it's the starter relay ..was clicking but when I got starter on today it didn't.. looks like two posts are dead on relay..got a price from parts place for 27.99..
  • kzrob
08 May 2015 14:46
#671159
Partzilla
