1992 KZ1000P Speedometer is off
Re: 1992 KZ1000P Speedometer is off
08 May 2015 16:32 - 08 May 2015 16:33
There are two brass rivets holding the shaft assy on. I'm thinking of drilling out them and useing pop rivets to put it back on after I check out the bushing. Might be able to drive it out and make a new one. I have my old one to play with so why not?
Last edit: 08 May 2015 16:33 by SWest.
- Bozo
- Ride it like u stole it
08 May 2015 17:20Swest, I haven't checked the Z1R speedo carefully but there must be a small container in line with the needle shaft holding oil. The reason I know is that when I accidentally left my speedo on its side I had an oil stain on the face.swest wrote: He also said something about a oil filled drum. There isn't one on these. I suspect the shaft is just sloppy and there is no way to fix that.
I know my FJ has a small container on the shaft with a nylon cap, when my speedo got erratic I used a needle with an oil from Toyota used on the thermo fan couplers and it worked till I replaced it with a GPS speedo.
08 May 2015 18:31
The shaft does NOT come out from the bottom. It is held in by the swedge in the magnet. It goes together then is swedged. Don't try it.
