Indicator/dash lights
02 May 2015 15:07
I just ordered these LED lights for my gauges and dash. I've been so tired of having them burn out so quick. In the day a bulb at home could last 15 years and did. The bike ones would last too. Not anymore. All you can get is junk from china or NOS that would burn out in no time. I'm going to give these a shot. Tell ya how it works out.
- missionkz
Re: Indicator/dash lights
02 May 2015 15:13
No eBay APP ID and/or Cert ID defined in Kunena configurationYes please do.... the ones I installed .... two of four had burned out LEDs within the first 120miles.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
02 May 2015 15:24
Crap, them too? I was going to buy that style but chose these as a experiment.
We'll see.
We'll see.
- RonKZ650
02 May 2015 17:30
LEDs are just like regular bulbs as far as reliability. Get good ones, like they use on the new motorcycles and cars and they last forever OEM. Trouble is in the aftermarket as some are good probably, but so many are pure garbage it's rediculous. I bought a slot machine and the bulbs started blinking and doing other goofball stuff the first couple hours I got it, and immediately thought LED. Sure enough, junk LEDs there. Replaced with regular bulbs and it lights up perfect. Hopefully you get a good part, as they are all made in China.
- bountyhunter
02 May 2015 18:19I went through the same dilemma and ended up springing for the expensive LED units from auperbrightleds.com instead of the cheap ones off ebay just because it is so much work to replace them. On mine, the screws at the front of the tach/speedo that hold the cover shells on had seized up from rust and sheared off trying to remove them (had to drill out the bracket and retap). Anyway, no problem now about two years later with the new LED bulbs.swest wrote: Crap, them too? I was going to buy that style but chose these as a experiment.
We'll see.
- bountyhunter
02 May 2015 18:21 - 02 May 2015 18:28Any decent LED should last at least 10,000 hours, but the stuff on ebay is all from China and quality is pretty bad. The cheap ones can't handle vibration.RonKZ650 wrote: LEDs are just like regular bulbs as far as reliability. Get good ones, like they use on the new motorcycles and cars and they last forever OEM. Trouble is in the aftermarket as some are good probably, but so many are pure garbage it's rediculous.
Last edit: 02 May 2015 18:28 by bountyhunter.
02 May 2015 18:56
I was hoping they would last as least longer than what they sell at AZ or OR for regular bulbs. I even got some NOS radio lights. 18v and they lasted a year. We'll see.
- bountyhunter
02 May 2015 19:28
These are the ones I used for instrument lights:
www.superbrightleds.com/moreinfo/ba9s-ba...-power-led/958/2359/
I have been running superbright LEds in tail, brake and turn signal for over ten years with no failures.
05 May 2015 07:02
Well I got them yesterday. One came apart as soon as I pushed down and twisted it. No glue, just pressed over the bayonet with the ground folded over. They're depending on the soldered wire to keep them together. They are brighter than the others so my faded colors look worse. The ones in the gauges don't work at all. I may have a bad connection. The guy is pestering me for a 5 star feed back. I'll wait until I make sure I have power to the gauges. If I do, I'll send him a message about the problem. It's not much money but that's two hours of my life I'll never get back.
The following user(s) said Thank You: missionkz
05 May 2015 19:34
Went out and checked the multi connector leading to the gauges and idiot lights. Found a blue wire fried and soldered it. Looked like metal fatigue. Four spade connectors were pushed in. I pulled them out, cleaned them and bent the keeping tang out so they wouldn't do it again. I've always known I need new connectors for the loom. After all, they're 40 years old. I've had problems with the others now this one. Z1 had them, maybe they still do.
05 May 2015 19:56
These folks have a bunch of vintage style connectors in case Z1E doesn't have what you need. Ed
www.hvccycle.com/electrical-connectors.html
www.cycleterminal.com/250-connectors.html
vintageconnections.com/
05 May 2015 20:15
Thanks Ed. The last one has what I need. Good prices too.
