techometer
  • jlat
  • jlat's Avatar Topic Author
techometer
27 Apr 2015 17:38
#669803
hello people; I'm new. K1 engine. How does it get the RPM's from the engine? My tack., speedo gauges have 4 blue wires coming from it that are gathered and connected to a single blue wire. It is electrical but I don't know how it picks up the RPM's?
IBBY
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: techometer
27 Apr 2015 21:13
#669828
You did away with the wiring loom didn't you? Two more things for your to do list. :woohoo:
  • martin_csr
  • martin_csr's Avatar
Re: techometer
28 Apr 2015 05:17
#669844
Maybe if the year & model were supplied, someone could provide a wiring diagram?
The electronic speedometers I've seen get the signal from a speed sensor & the electro tachs get the signal from the ignition system --- typically from the black wire that provides the signal to the 1-4 ignition coil.
  • jlat
Re: techometer
29 Apr 2015 17:48
#670035
hello people; Sorry for not knowing more info. on what I have but I still have the engine that came from the harness and gauges. I bought that bike for parts years ago, thru out the frame (stupid move) stock airbox (stupid) and exhaust (stupid) . I have most of the rest but it was a beat bike and alot of things where dented and broke, The engine ID # is KZT00AE106032 and it's all black if that helps? IC igniter iggy and square valve cover not like a Z1 style.
IBBY
  • jlat
Re: techometer
02 May 2015 16:06 - 02 May 2015 16:08
#670416
hello people; I'm new and you Kaw heads are letting me down. I'm waiting for my head to come back and the wiring has to be done but I have to know about the gauge wiring. The engine I have the harness for has all that hoses that come of the valve cover. It has to be smog?
IBBY
Last edit: 02 May 2015 16:08 by jlat.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: techometer
02 May 2015 16:24
#670417
Being you have removed all the original wiring, you'll have to get a manual for what it once was and figure out where things went and where they go now. When someone brought a hacked up bike to my shop, I sent them home with it. :whistle:
  • jlat
Re: techometer
02 May 2015 16:44
#670422
hello people; That's what I'm here for the clues are here so a Kaw head should know what model I have
for me to continue.
IBBY
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: techometer
02 May 2015 16:51
#670424
So you don't have a manual. Anyone of us would have to look it up, why not you?
  • jlat
Re: techometer
02 May 2015 16:59
#670428
hello people; From what I've said what model is what I have a harness and gauges for? I could try and find the answers but if someone would know why strain my brain?
IBBY
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • jlat
Re: techometer
02 May 2015 17:07
#670431
hello; Well, Any help?
IBBY
Re: techometer
02 May 2015 20:15
#670457
Good Fortune! :)
