Dyna-S Ignition drawing too much power?? KZ650
- Spencer440
07 Apr 2015 06:55
I currently have a 79 KZ650-C3, with everything else is stock as far as the electrical besides the Dyna-S ignition system. Currently, my problem is that it doesn't seem to be charging the bike enough to keep the voltage up. I noticed that when the headlight is off, and the bike is on, it charges normally around 13-13.5 volts. But, with the lights on, and the bike running, it drops to 12.7-12.8 volts and slowly drops about 0.01 volts per 15-20 seconds. What could I do to remedy this? Is there a different stator setup that I could use? Anyway I could regulate the voltage higher? Thanks!
1980 KZ440-B
1979 Kawasaki KZ650-C3
Re: Dyna-S Ignition drawing too much power?? KZ650
07 Apr 2015 07:09
Should be 14-14.5 volts. Charge the battery then disconnect it. Leave it over night. If it loses power, it's the battery.
- gbot9000
08 Apr 2015 14:09
Not sure what stator you have on your bike, but there are ALOT of threads on here were people are having same issue using Dyna S on a single-phase stator. Some have upgraded to 3-phase system with better results.
kzrider.com/forum/4-electrical/594097-kz...ing-issue-bad-stator
79 kz650
- 78kzturbo
08 Apr 2015 17:53
Sounds like a stator or voltage regulator problem .
- Tyler
09 Apr 2015 00:34 - 09 Apr 2015 00:38
Typical problem, I went through the same thing. Chances are everything is working just fine. The dayna ingintion charges the coils longer than points do every time they discharge. The current draw is all the single phase charging system can handle. Some people can get by and others can't. It depends on your riding habits wether or not you can keep a charge in the battery. I found some used parts and put the stator and regulator from a 750 in my bike. Solved the problem.
gbot9000 posted the link to my fix above.
"74 Yamaha DT 400 Enduro
Last edit: 09 Apr 2015 00:38 by Tyler.
