92 KZ1000P-front turn signal wiring
- Dan KZP
Does anyone know how to wire these things back up?
I have a wiring diagram that I will be following later this morning but it will be nice to know I'm on the right path.
Dan
- MFolks
- Thank you received: 540
- MFolks
So for the front turn signal/running lights, you'll have three wires going to each one; Blue, Black/Yellow, and then the signal circuit, either Green or Grey.
- Dan KZP
I was able to find these wires coming out of the harness for the left and right sides.
The signal lights that are on the bike appear to be some kind of LED which was used by the PO for flashing lights.
I'm restoring the lights on the bike to OEM as I can't get these lights to work.
I found these but the description says two wire??? I thought I would need a three wire signal light set up.
Does this light look right?
www.z1enterprises.com/ItemDetails.aspx?i...Z1000&item=KS25-2015
Dan
- MFolks
www.kandstech.com/productreleases/newprod199.pdf
- Thank you received: 2829
- HBKwaka
- Visitor
Attachment IMG_1070.jpg not found
- Dan KZP
The ground wire is actually bolted to the mounting plate.
I didn't see that in the other pictures but it's clear in the pictures Ed posted from ebay. Thanks Ed
Dan
- Dan KZP
I went with the K & S signal lights from Z1 Enterprises and they were just about a plug and play item.
Dan
- bountyhunter
- Thank you received: 337
Dan KZP wrote: You guys nailed it.
I still think the cop bikes have a different harness and one of the things that is different is how those front running lights work.... because around here, those lenses were red on every cop bike and they turned on solid every time they went to pull me over. Not sure if they also functioned as turn signals.... in 45 years of driving, I have never seen a cop use a turn signal. :laugh:
- HBKwaka
- Visitor
- Dan KZP
These replacement lights had two wires, one for the parking light and one for the turn signal. The light is gounded though the light housing.
Dan
