92 KZ1000P-front turn signal wiring
- Dan KZP
03 Apr 2015 04:20
I need to connect the OEM turn signals on the front of the bike. Trying to restore stock configuration.
Does anyone know how to wire these things back up?
I have a wiring diagram that I will be following later this morning but it will be nice to know I'm on the right path.
Dan
- MFolks
Re: 92 KZ1000P-front turn signal wiring
03 Apr 2015 06:50
I'd imagine the blue wires are for the front running lights, with Green for one side, and Grey for the other.
- MFolks
03 Apr 2015 06:54
Black with Yellow stripe is the ground for almost every Kawasaki I've owned(except for the heavy duty Negative battery cable).
So for the front turn signal/running lights, you'll have three wires going to each one; Blue, Black/Yellow, and then the signal circuit, either Green or Grey.
- Dan KZP
03 Apr 2015 08:50
You guys nailed it.
I was able to find these wires coming out of the harness for the left and right sides.
The signal lights that are on the bike appear to be some kind of LED which was used by the PO for flashing lights.
I'm restoring the lights on the bike to OEM as I can't get these lights to work.
I found these but the description says two wire??? I thought I would need a three wire signal light set up.
Does this light look right?
www.z1enterprises.com/ItemDetails.aspx?i...Z1000&item=KS25-2015
Dan
- MFolks
03 Apr 2015 13:52
That's a rear turn signal. For the front ones, you'll need three wires. The bulbs for these will be #1157 for the front signals/running lights and the brake/running light. And # 1156 for the turn signals. Ask at
and see if they can get some K & S turnsignals for you.
www.kandstech.com/productreleases/newprod199.pdf
03 Apr 2015 14:02
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHere are (used) front KZ1000 Police turn signals:
- HBKwaka
03 Apr 2015 15:26
s is wat is on my KZP when I bought it. They only work as indicators. They only have one wire. They are incandescent not LED.
Attachment IMG_1070.jpg not found
- Dan KZP
03 Apr 2015 16:27
Thanks for the help. I was looking at the ones I ordered and they are for the front.
The ground wire is actually bolted to the mounting plate.
I didn't see that in the other pictures but it's clear in the pictures Ed posted from ebay. Thanks Ed
Dan
- Dan KZP
06 Apr 2015 16:24
The signal and parking lights are working. Thanks for your help.
I went with the K & S signal lights from Z1 Enterprises and they were just about a plug and play item.
Dan
- bountyhunter
06 Apr 2015 17:23 - 06 Apr 2015 17:24Dan KZP wrote: You guys nailed it.
I still think the cop bikes have a different harness and one of the things that is different is how those front running lights work.... because around here, those lenses were red on every cop bike and they turned on solid every time they went to pull me over. Not sure if they also functioned as turn signals.... in 45 years of driving, I have never seen a cop use a turn signal. :laugh:
Last edit: 06 Apr 2015 17:24 by bountyhunter.
- HBKwaka
06 Apr 2015 20:19
My front signals are aftermarket and single wire.
- Dan KZP
07 Apr 2015 14:57
I've seen some pic's of the KZP where the pursuit lights were red but don't recall seeing signal lights red.
These replacement lights had two wires, one for the parking light and one for the turn signal. The light is gounded though the light housing.
Dan
