Stator Wire New Grommet Reinstall
  • martin_csr
  • martin_csr's Avatar
Re: Stator Wire New Grommet Reinstall
06 Mar 2015 03:49 - 07 Mar 2015 03:31
#663623
daveo wrote: :huh: Wouldn't the application of silicone spray prevent a bond/seal from forming when installing the grommet in the cover?
Um, clean off the silicone spray after feeding the wires thru. easy.
Although a new grommet will probably give a good seal, if concerned about leaks, I would probably use Seal-All .
Last edit: 07 Mar 2015 03:31 by martin_csr.
  • MFolks
  • MFolks's Avatar
06 Mar 2015 09:36
#663632
www.z1enterprises.com used to sell the grommet. When I used to work with tight fitting Mil-Spec aircraft and missile electrical connectors, Rubbing Alcohol worked really good as a lubricant, as it would evaporate, leaving no residue.
  • SweetwoodSUP
  • SweetwoodSUP's Avatar
06 Mar 2015 22:03 - 06 Mar 2015 22:08
#663663
I just did mine a couple of weeks ago. I had the same problem getting the wires through but I shot a little white lithium grease on the wires and they slipped right through.
I was also very pleased that the new stator came with wires long enough that I was able to run them all the way to the rectifier. Then I soldered them so now my stator is hard wired to the rectifier (new rectifier too). Some shrink tubing, cut the old wires out and it is now cleaner looking and in function. Before it had to go through two sets of connectors. Now there is less room for corrosion to foul things up. :)
'79 LTD 1000
'84 Ninja 900 (Sold, What was I thinking!)
'81 CSR 305 (sold)
'69 BMW R75 (Sold)
Last edit: 06 Mar 2015 22:08 by SweetwoodSUP.
