81 750 4 headlight and horn
- pcompton
24 Jan 2015 06:21
Hey guys,
I have a 81 750 4. My horn stopped getting power awhile back but I didn't think anything about it figured it was the horn got a new one turned out it wasn't getting power. Now my headlight quit getting power I checked the fuses under the left side cover but I didn't see anything blown. Can someone shine some light for me I'm getting a little frustrated. Thanks guys!!
1981 kz 750 4
1979 kz 750 twin sold
Re: 81 750 4 headlight and horn
24 Jan 2015 07:21
Could be in the ignition switch. The backing plate can get loose. It's just swedged on. Clean and lube the contacts by spraying carb cleaner then grease, tighten the indentation (swedges) and see if it works. Common problem on old switches.
The following user(s) said Thank You: pcompton
- MFolks
24 Jan 2015 07:26
I'd open up the switch "Pod", that has the horn button on it, looking for failed solder joints, as these bikes are starting to see the factory solder jobs, that really were not the best. The other pod that has the run/stop and start switch probably needs inspection too.
- pcompton
24 Jan 2015 10:38
I'll take a look at them soon. Thanks
1981 kz 750 4
- spdygon
24 Jan 2015 11:27 - 24 Jan 2015 11:28
at least om my 77kz1000ltd...there is not power ( line voltage) to the horn button.
Power goes to the horn directly.....at the horn button only ground is present.if you have change the handlebars from chrome to painted ones.....you may not be getting ground.
i spent about 2 hours on this....
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Last edit: 24 Jan 2015 11:28 by spdygon.
