kz 440 ltd ignition problem
  • timkz440ltd
  • timkz440ltd's Avatar Topic Author
18 Oct 2014 20:01
#651075
Hey guys so I joined the forum to ask about a problem I've been having. So last year I bought 2 kz440s for 800$. The better off the two was running great in the fall until one cylinder stopped firing on a cold day. It was dumping gas through the cylinder so I assumed the float was stuck. So I took apart the carbs and cleaned everything up put it back together and still had the same problem. I then took the coil from the other bike and swapped it over and it seemed to work and both cylinders fired just fine, until a few months later and then it was running off one cylinder at start up but the second cylinder would kick when it got warm and I started riding. Compression is good, carbs are good, plugs are good, battery is new. Just seems odd that bowl coils worked for a little while then started giving me problems. Both coils still do send spark just fine though. Anyone have an idea on what it could be? Thanks for the help
Re: kz 440 ltd ignition problem
18 Oct 2014 20:36
#651077
Hello, timkz440ltd, and WELCOME to KZr! :cheer:
If not already done, would suggest assuring valve clearances are within specs, and also perform the clear tube test to determine whether fuel levels are within specs.
Good Fortune! :)
  • 60ratrod
  • 60ratrod's Avatar
19 Oct 2014 00:22
#651092
That's weird, normally coils fire fine cold and drop off when they get hot. Check the condition of the spark with the bike cold. You should be seeing nice fat blue spark. I would also start checking all connections for corrosion.
Active Duty US Navy Aviation Ordnanceman Petty Officer First Class
81 kz1000m1 csr "Sarge"
81 Suzuki gs650g "Shelah"
  • bountyhunter
  • bountyhunter's Avatar
19 Oct 2014 00:43
#651093
timkz440ltd wrote: Hey guys so I joined the forum to ask about a problem I've been having. So last year I bought 2 kz440s for 800$. The better off the two was running great in the fall until one cylinder stopped firing on a cold day. It was dumping gas through the cylinder so I assumed the float was stuck. So I took apart the carbs and cleaned everything up put it back together and still had the same problem. I then took the coil from the other bike and swapped it over and it seemed to work and both cylinders fired just fine, until a few months later and then it was running off one cylinder at start up but the second cylinder would kick when it got warm and I started riding. Compression is good, carbs are good, plugs are good, battery is new. Just seems odd that bowl coils worked for a little while then started giving me problems. Both coils still do send spark just fine though. Anyone have an idea on what it could be? Thanks for the help
The single coil on a twin fires both spark plugs in series. Pretty unusual to have one spark firing with no spark on the other. Only happens if the coil has one end of the high voltage shorting to ground either internally or externally as with a plug wire arcing to chassis.
  • ShaCvet
  • ShaCvet's Avatar
19 Oct 2014 11:05
#651132
I own a KZ400 which in a sense is the same bike. I would highly recommend purchasing a electronic ignition for 7thgeardesigns.com. My coil gave me similar issues then finally quit working.
1979 KZ400 B2 fully restored and powder coated.
