Dead KZ1000
  • Vter Bob
  • Vter Bob's Avatar Topic Author
Dead KZ1000
07 Aug 2014 18:57
#643101
So, I thought I would take the KZ1000 for a little ride today. I went out, unplugged the battery tender, rolled her out of the garage. Put my gear on, hoped on and stuck the key in the ignition. Turned her on and NOTHING, No lights, no horn, no start! I think she is jealous of the Connie...
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
1999 ZG1000 Concours
Greetings from the Peoples Republic of Vermont, home of Ethan Allen, 2 American Presidents, a socialist US Senator and.....Homer & Bart Simpson
  • MFolks
  • MFolks's Avatar
Re: Dead KZ1000
07 Aug 2014 19:11
#643104
Got a multimeter? You'll need one to see where the power is and isn't. I'd replace all of the fuses. I believe yours are AGX in size, with 10,15,and maybe 20 amp ratings. AGX might be available at auto parts stores or boating supply places.
  • RonKZ650
  • RonKZ650's Avatar
Re: Dead KZ1000
07 Aug 2014 19:17
#643105
That could be, but my own experiences on older KZs probably one of three things. Blown main fuse most likely, shortly followed by dead battery. I've actually found using a battery tender causes many a dead battery, and they can be fine then the second current flows as in turning on the key, short out to zero volts. Last thing I've seen is melted wire connections on the ignition switch from bad contacts in the switch. All these KZ650 or older KZ1000, not sure 1982 they may have improved electrics for all I know on them new models. :lol:
The following user(s) said Thank You: PLUMMEN
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
Re: Dead KZ1000
08 Aug 2014 01:12 - 08 Aug 2014 01:12
#643125
Check to assure both connections, at the battery, are tight. I found the ground at the battery, on my 650, was just slightly loose and it took me almost forever to find this simple problem... well, a few hours.
Also, got 12+vdc at the battery? Break out the meter...
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Last edit: 08 Aug 2014 01:12 by !Seymore.
  • pete greek1
  • pete greek1's Avatar
Re: Dead KZ1000
08 Aug 2014 09:44
#643150
Also check the fluid in your battery , some tenders that do not automatically turn off when battery is fully charged will cause the battery to heat up, & make your fluid evaporate
ask me how I know :(
that's why I invested in a CTECH charger (smart charger)
Pete
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Dead KZ1000
12 Aug 2014 11:46
#643648
The fact i is DEAD means (unless the battery is 0 volts-which never really happens) then your problem is probably the main fuse blown. If not then check the B+ to fusebox wiring connector, then fusebox to ignition switch block connector.
IIRC all fuses are powered by the main fuse on a z1000, goes from main fuse to ignition switch and back to power the other fuses. It is easy to blow a main fuse when working around the battery area, nothing to worry about.
Re: Dead KZ1000
12 Aug 2014 11:52 - 12 Aug 2014 11:56
#643650
Check your fuses with a meter. The glass tube fuses can look fine but have the filament disconnected at an end cap. This can happen even when there is no electrical problem; usually from old age or vibration. Ed
Last edit: 12 Aug 2014 11:56 by 650ed.
  • Vter Bob
Re: Dead KZ1000
12 Aug 2014 18:03
#643705
I appreciate all the suggestions! I haven't had any time to do a thing with the 1,000. (Work and the Connie take up most of my time) But this weekend I will take some time to try to get her running again. As far as the battery, it's a 2 year old AGM battery and it reads 12.9 volts across the terminals.
Georgia, Vermont
1981 KZ550 LTD
1982 KZ1000 LTD
