Flat wiring harness
- Lazyman06
Flat wiring harness
05 Aug 2014 17:47 - 05 Aug 2014 18:50
Thinking about experimenting with making a flat harness by leaving the wires unbundled and wrap them around the frame with something like Saran wrap so when you look through the bike you don't really see anything except the wires.
My thinking is the advantages to it would prevent wire rubbing, easier to track down wiring in case something goes wrong and heat would dissipate easier if current gets too high. I'm not going to have turn signals, horn, and only going to a dirt bike kill switch on the bars so wiring, at least on the front will be scarce. What do y'all think.
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Last edit: 05 Aug 2014 18:50 by Lazyman06.
- kaw-a-holic
Re: Flat wiring harness
05 Aug 2014 19:29
Sounds cool, make sure you post pics if you do it. I decided to pony up the cash for a Motogadget M-Unit. It will have a single wire running from handle bars to the control module. I will be doing a full pictorial soon.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
