8-pin connector reuse
- diego092409
22 Jul 2014 18:32
I am installing a new fuse box in my 1982 gpz 1100 b2. I would like to connect the new harness directly into the existing 8 pin connector. How would I go about either reusing the existing connector and/or getting a new compatible connector. What is the connector standard that was used in this model year? z1 enterprises sells kl34 connectors. Is that the correct series/standard?
1982 KZ1100 B2 - 'Old Red'
kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
2015 BMW K1600GT
Re: 8-pin connector reuse
22 Jul 2014 18:40
Once you determine what type connectors you need, here are a couple places that sell vintage connectors. Ed
www.hvccycle.com/electrical-connectors.html
vintageconnections.com/
- MFolks
22 Jul 2014 19:17
Another is:
www.easternbeaver.com
23 Jul 2014 06:51 - 23 Jul 2014 07:08
When Installing a Ninja 500 voltage regulator, I got the needed stuff from CycleTerminal.com which has a pretty good selection (two orders in the past year). The Sumitomo 250 & .110 connectors are a good match to the KZ.
CycleTerminal --- Connectors
CycleTerminal --- Terminals
CycleTerminal --- Tools -- Open Barrel Crimper & Terminal pin extractors
The pin extractors are good quality. I already had a HarborFreight ratcheting crimper, but it has the wrong crimper dies, so I got a set for open barrel terminals from Amazon.com.
Last edit: 23 Jul 2014 07:08 by martin_csr.
