10.5 Volts at the tail light
  • djturnz
  • djturnz's Avatar Topic Author
01 Jul 2014 07:19
#638560
I assume it's supposed to be 12v, right?
I need to go through my system with contact cleaner and clean everything up. I was trying to hook up a 6 inch LED strip that I want to use to light my license plate, but it won't light hooked to the tail light wire. Across the battery terminals it will though. At least with the key on, but motor off it won't turn on.
Maybe it would with the alternator doing work, but either way my system needs cleaned.
I am going to be doing a lot of riding next weekend and I was hoping to have this done by them. Hopefully I can find the time next week.
1982 KZ750 (4) LTD
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 10.5 Volts at the tail light
01 Jul 2014 08:36 - 01 Jul 2014 08:38
#638568
ya, sounds like a bad wire, connection or ground.
a good connection cleaning, check for bad, cracked or frayed wires.
check the wires with a volt meter. go from a tail light and move back checking for good voltage.
always check out ground.
I guess you have good voltage at other items on bike?
Last edit: 01 Jul 2014 08:38 by 4TheKZ1000.
  • MFolks
  • MFolks's Avatar
01 Jul 2014 10:11
#638578
Print,and keep this in your toolbox:
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
The following user(s) said Thank You: djturnz
  • djturnz
05 Jul 2014 14:51
#638975
Battery water was low. I filled with distilled and it's on trickle charger now. I went through and sprayed all the connections behind the battery box and inside the headlight bucket. I'll find out tomorrow if any off this made a difference. Thanks
1982 KZ750 (4) LTD
  • pete greek1
  • pete greek1's Avatar
05 Jul 2014 15:05
#638977
Make sure to check your ground ,from the battery to the frame ,or engine !!
Pete
