The things that go blink blink :)
- jtpvg
27 Jun 2014 18:34
So when I started this project I had done away with the turn signals (and a few other things). Well after getting cursed out and honked at a few times I want to put them back. I dont want the running lights so Im leaving them out. My problem is after mocking some up I cant get ANYTHING. Cant even get them to stay on. I'm not sure what the problem can be! Maybe the relay went bad, Maybe its the switch itself. I can usually figure these things out but I'm at a loss right now. Any ideas would be greatly appreciated.
82 kz 1000 Cafe Racer
82 xj 750
photobucket.com/user/jtpvg/library/82 KZ 1000?sort=3&page=1
82 xj 750
- MFolks
Re: The things that go blink blink :)
27 Jun 2014 19:25
I'd start with know good bulbs, & flasher relay(get the electronic one, if you want to use LED's in the future). Are the turn signal sockets and turn signal switch still good? Harness uncut?
- jtpvg
27 Jun 2014 20:33
Its the exact same way it was when I took the old ones off. All I did was tuck them up and zip tied them. It is the factory signals im trying to use and I tested them and they work just not with the blinker switch. I can go and get a new relay tomorrow. Does anyone know the model # of a good one I can use?
82 xj 750
82 xj 750
- MFolks
27 Jun 2014 20:51
I don't have any part #, but most auto parts stores sell the electronic ones, bring your old one along, to compare the electrical connections(pins), as some are two, or three pins. Also, open up the handlebar pod, that has the turn signal switch, as it may be corroded, or have failing solder joints. Some of the older Kawasaki's are seeing this happen.
The following user(s) said Thank You: jtpvg
- Beaner242
27 Jun 2014 20:59
Is there a separate fuse for the blinkers?
1982 KZ1000K LTD Chopper
- jtpvg
27 Jun 2014 21:02
I remember when I updated my other bike I had to go from a 3pin to a 2 pin. I didn't know if it would be the same with this bike. But I will take the switch apart as well tomorrow and see if something is wrong in there and try and bypass the switch to see if it is the switch or not. I can cut, weld, and fab but I HATE electronics!!!
82 xj 750
82 xj 750
- jtpvg
27 Jun 2014 21:03Beaner242 wrote: Is there a separate fuse for the blinkers?
I checked that and it is good.
82 xj 750
82 xj 750
- jtpvg
09 Jul 2014 14:04
It turned out to be the relay. Got a new electric one and hooked it up and BOOM, it works. So I went to put new LED signals on and they wont flash. They just stay lit, but if I take the old light and wire them in with the LED ones they all flash. What gives? This is driving me CRAZY!! lol!!
82 xj 750
82 xj 750
- kaw-a-holic
09 Jul 2014 16:09Back to the parts store for you sir. You have to get a flasher for LED lights. They have less draw so they will not flash. At least you found the issue.jtpvg wrote: It turned out to be the relay. Got a new electric one and hooked it up and BOOM, it works. So I went to put new LED signals on and they wont flash. They just stay lit, but if I take the old light and wire them in with the LED ones they all flash. What gives? This is driving me CRAZY!! lol!!
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- jtpvg
09 Jul 2014 16:34
Yeah I just assumed the one one I had got for my other bike would work but I do have the original back turn signals for that bike. I believe I need one that is low load with a ground right?
82 xj 750
82 xj 750
- kaw-a-holic
09 Jul 2014 20:06jtpvg wrote: Yeah I just assumed the one one I had got for my other bike would work but I do have the original back turn signals for that bike. I believe I need one that is low load with a ground right?
I bought mine at O'reilly Auto parts. Brand is In Line, LED flasher P/N is EFC212RL 2P-12V
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
- jtpvg
10 Jul 2014 13:01
they didnt have that at my oriellys but a guy at autozone just went through the same and sold me.what he used and it works. It has to be grounded but atleast they go blink blink
82 xj 750
82 xj 750
