Replacing coils in my KZ650B2
  • OLKZ
  • OLKZ's Avatar Topic Author
26 May 2014 15:55
#634058
Working on replacing the coils on my KZ650B2 1978.
This is the first step before installing Dyna ignition.
You should see how nasty my old coils were:
1978 KZ650B2 - Blue - runs!
New Dyna-S ignition & coils 6-2014
  • OLKZ
Re: Replacing coils in my KZ650B2
26 May 2014 15:59 - 26 May 2014 16:41
#634059
Got the first coil hung, facing downwards and forwards per the docs that came with it. The mounting is improvised, as the old bolts were too short. Used M6-1.00 x 40 bolts, same thread as old ones. Nylon stop nuts and nylon spacers on the bolts.
Since I'm a belt-and-suspenders kind of guy, I crimped AND soldered the primary wires.
Think my mounting is ok?
Attachment P5260322.jpg not found
Last edit: 26 May 2014 16:41 by OLKZ. Reason: Add photo
  • OLKZ
26 May 2014 16:47
#634062
Here's a concern I have: The yellow/red wire is very close to the head of the mounting bolt. I'm a little worried it might arc to ground there, although that's only 12 volts, so maybe it's not likely. I tried very hard to get a decent photo of it but all the pix I took are pretty bad. What do we think?
Attachment P5260325.jpg not found
Attachment P5260326.jpg not found
Attachment P5260330.jpg not found
  • azman857
  • azman857's Avatar
26 May 2014 18:05
#634069
You can get some flat stock and drill it to mount it in stock location and another set of holes about a 1/2" away to the side for the wider spacing mounting holes to get further away the terminal.
  • MFolks
  • MFolks's Avatar
26 May 2014 19:18
#634078
Or, get some of the clear RTV compound, and overcoat the ignition coil terminal, it will act like an insulator, and prevent vibration from loosening the terminal screws. It will peel off, if needed.
  • KZB2 650
  • KZB2 650's Avatar
27 May 2014 08:22
#634148
I used about 3 layers of electrical tape on mine ...... not real pretty but hopefully will work.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • turboking
  • turboking's Avatar
27 May 2014 09:32
#634151
+1 on the RTV :blink:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • OLKZ
27 May 2014 11:34
#634158
:) Hmm- that's a good idea, modifying the mount with a piece of flat stock. Mebbe I'll try that.
Thanks.
  • Cynjut
  • Cynjut's Avatar
27 May 2014 13:12
#634169
I drilled a new hole in the bracket and used the other mounting hole. I also installed it with the screw head on the outside so that it wasn't as tall.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • Tyler
  • Tyler's Avatar
28 May 2014 21:44
#634389
OLKZ wrote: Here's a concern I have: The yellow/red wire is very close to the head of the mounting bolt. I'm a little worried it might arc to ground there, although that's only 12 volts, so maybe it's not likely. I tried very hard to get a decent photo of it but all the pix I took are pretty bad. What do we think?
Mine look identical to yours, you don't need to insulate that screw, it's only 12 volts it can't jump a gap.
your still running points at this point? These coils will work but they will be a little hard on the contacts. Not a problem if you go to a electronic ignition soon.
"74 Yamaha DT 400 Enduro
  • OLKZ
03 Jun 2014 17:27
#635222
I haven't fired it up since installing the coils, because the Dyna electronic ignition kit arrived and I'm installing it. But I did change things a little to increase the gap between the bolt head and the primary contact. Read on (next few posts)
  • OLKZ
03 Jun 2014 17:40
#635225
The close proximity of the mounting bolt and the screw terminals made me slightly nervous, so I ground the head of the bolt to a small bevel. See photo. The coil is spaced away from the frame with nylon spacers, so I couldn't tighten the nut too much anyhow, so I don't see myself regretting the loss of purchase area for a socket or box wrench.
I also replaced the split washer with a star lockwasher, which is less bulky.
The result is nearly a quarter-inch of gap, which makes me a little more happy.
Attachment P5310353c.jpg not found
Attachment P5310357cr.jpg not found
