Power at Ignition Coil KZ1100
- Poopboy
Re: Power at Ignition Coil KZ1100
13 May 2014 12:27
How would I do that? I just got a used coil in them mail and will try to swap it tomorrow. Can you meter through the ignitor? Or are you talking about the wire from the pickup to the wiring harness?
- Poopboy
14 May 2014 17:22
I had a few minutes today so I unplugged the old ignitor and plugged in the "new" old one and checked for spark. I had spark on all 4 cylinders so all is good now. Thanks for your help. I should be able to install it tomorrow and see if the bike runs better on 4 cylinders than it does 2. Then I will just have to check the valves and replace the master cylinder and should be good to go. Hopefully.
- Poopboy
16 May 2014 06:36
I installed the ignitor box, put a hose clamp on the carb boot and she idled perfect. I am waiting on a master cylinder then I can see how it rides. I finally had a project bike that took less than $100 worth of parts to get it on the road. :woohoo: So I have $350 in the bike total.
