what is the clutch lever switch for on a 1980 kz
  • tattooDan
  • tattooDan's Avatar Topic Author
04 May 2014 23:42 - 04 May 2014 23:44
#631351
stupid question probably,but what is the clutch lever switch for on a 1980 kz1000 shaft ? what does it do ? can I get rid of it ? I am changing the bars and some of the controls on them.
1980 KZ1000E ST/SHAFT
Last edit: 04 May 2014 23:44 by tattooDan.
  • koolaid_kid
  • koolaid_kid's Avatar
Re: what is the clutch lever switch for on a 1980 kz
04 May 2014 23:50
#631353
Sounds like the starter interlock. You have to pull the clutch in for the starter to work. Connect the two wires together and do away with the switch. Then you can start it without the clutch being pulled in.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
The following user(s) said Thank You: tattooDan
