Oil at stator bullet connectors?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
23 Mar 2014 17:50
#626304
I'm baffled. Looking at the three bullet stator connections (yellow wires), there is oil on them. Could oil be getting pushed out between the yellow jackets and copper wires? I have no clue how it arrives there, since there is none on the outside of the wires. :huh:
1982 KZ1100-A2
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Oil at stator bullet connectors?
24 Mar 2014 05:35
#626327
Physically impossible. I suggest you continue to look elsewhere.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
  • daveo
  • Premium Member
  • Premium Member
24 Mar 2014 06:47
#626331
koolaid_kid wrote: Physically impossible. I suggest you continue to look elsewhere.
I agree! Perhaps the infamous oil-drop fairy...
1982 KZ1100-A2
24 Mar 2014 10:33
#626364
Perhaps not oil, but residue of dielectric grease that was sloshed on the bullet connectors at an earlier time.
Good Fortune! :)
  • daveo
  • Premium Member
  • Premium Member
03 Jul 2015 22:06 - 04 Jul 2015 17:34
#679345
A couple days ago, I finally sealed the wires with Three Bond 1211 after replacing the bullets with crimp connectors.
I discovered that oil had in-fact been seeping out between the copper wires, and rubber yellow-sheaths. :ohmy:
Believing it impossible, I've been wiping up oil for months...and finally had enough of it. Sorry.
NO LEAKS NOW!!! :cheer:
1982 KZ1100-A2
Last edit: 04 Jul 2015 17:34 by daveo. Reason: Add pic
  • Tyrell Corp
  • Tyrell Corp's Avatar
04 Jul 2015 05:44
#679362
That is one of those jobs I expect on old bikes now, the bullet connectors get heat baked and brittle and it is such an easy job to sort out. Your solder and heat shrink seems better than insulated bullets there.
  • SWest
  • SWest's Avatar
  • 10 22 2014
04 Jul 2015 06:10
#679367
It is possable for oil to "wick" along the wires and in between them and the insulators. When I replace the grommet I'll clean the bare wires and use super glue to seal them. Hate oil on my left foot. :evil:
  • weales
  • weales's Avatar
06 Jul 2015 16:11
#679725
Maybe should be looking for the source of the oil, rather than trying to stop it leaking out from the inside of the alternator cover? Sounds like the oil is coming past the oil seal on the LH end of the crank. Capillary action would explain how the oil is wicking up the alternator output wiring. If the oil continues to build up inside the alternator area, it could eventually drip out through the grommet onto your left boot again! Replacing the bullet connectors with crimp splices and superglueing them is a bit severe - this makes separation of the alternator output wiring from the main harness a bit more involved - but hey, it's your bike and if it fixes your problem then no problemo!
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Jul 2015 16:31
#679726
I don't think you understood what I said. You buy a new grommet, cut the wires inside or out, clean off the oil with spray carb cleaner and seal the wires on the inside with the glue. The idea is to get the glue inside the insulation so it won't wick. The new grommet is larger than the opening so when it squishes down, it seals everything. The grommet vulcanizes around the wires with heat and so does the insulation.
  • weales
  • weales's Avatar
06 Jul 2015 16:43
#679729
Thanks for the clarification, but I still think that this is maybe chasing the symptom rather than the cause.? If the "oil" is just the dielectric stuff that's used during manufacture of the alternator wiring/assembly then fine - but if it's engine oil then there's another underlying issue.
Current Project
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
  • daveo
  • Premium Member
  • Premium Member
06 Jul 2015 16:50
#679731
Oil bathes the generator system in the J-engine. It purposefully flows out of the block through a hole above the starter gear, then back into the oil pan through an opening below the rotor.
Perhaps oil gets thrown behind the stator by centrifugal force of the rotor, especially while the motor is running at higher RPMS. :unsure: It may also be enhanced by internal engine pressure pushing the oil into that area, usually forcing oil past the wires where fed through the wedge-shaped rubber grommet, requiring that sealer be applied there.
Whatever it is...it was.
1982 KZ1100-A2
  • daveo
  • Premium Member
  • Premium Member
06 Jul 2015 17:01
#679733
swest wrote: I don't think you understood what I said. You buy a new grommet, cut the wires inside or out, clean off the oil with spray carb cleaner and seal the wires on the inside with the glue. The idea is to get the glue inside the insulation so it won't wick. The new grommet is larger than the opening so when it squishes down, it seals everything. The grommet vulcanizes around the wires with heat and so does the insulation.
I'm surprised that these three yellow stator wires are in such supple condition, whereas an earlier installed stator on the engine had wire insulation so hard it would crack when flexed even a tiny amount. Something must be working right in that regard now, as the generator system tops out at 14V steady, while running...well maintained by a Ricks (no-brown wire) regulator rectifier installed a couple years ago.
The battery has never been happier. :)
1982 KZ1100-A2
