Kz650 wiring mystery
  • Britome
  • Britome's Avatar Topic Author
14 Feb 2014 14:47
#622255
Bike hasn't run for years and it is one problem after another. I know nothing about history.
Can anyone tell me what wires go where? I've tried every combination I can think off.
You can see the two grey ends from the front turn signals pointing at each other. Then two greens and a grey that run in the main harness to the rear. I know some combination should give me signals but 5 wires means someone is going to be left out with a dance partner. Please help!
Attachment ImageUploadedByTapatalk1392418020.049647.jpg not found
Re: Kz650 wiring mystery
14 Feb 2014 16:35 - 14 Feb 2014 18:34
#622262
Please add the year and model of your bike to your signature line. There are numerous different wiring configurations for KZ650s. Ed
Last edit: 14 Feb 2014 18:34 by 650ed.
  • Britome
14 Feb 2014 18:00
#622278
Sorry. 1978
  • Britome
14 Feb 2014 18:00
#622279
Technically sr650
14 Feb 2014 18:32
#622281
The 1978 KZ650 SR is the 1978-D1 model. There should be a grey wire and a blue wire coming from the right turn signal (along with a black/yellow ground), and there should be a green wire and a blue wire coming from the left turn signal (along with ah black/yellow ground). The blue wire from each turn signal stalk powers the front running lights. The grey is the right blinker; the green is the left blinker. There should also be a grey and a green that connects to the 9-pin connector, and those power their respective turn signal indicators on the little lighting cluster between the gauges (where the oil light, brake light, neutral light etc. are). Below is a link to the wiring diagram for the KZ650-D1, and below that is a picture of the turn signal wiring inside the headlight shell. Ed
diagrams.kz650.info/wiring/images/KZ650-D1.jpg
Attachment IMG_0177.jpg not found
  • Britome
14 Feb 2014 18:44
#622283
You are amazing. I'll check it tomorrow. Thank you!
  • Britome
14 Feb 2014 18:50
#622284
No matter what combination I did, I couldn't get any turn signals. I'll be fresh for it tomorrow.
  • Britome
14 Feb 2014 19:12
#622291
I couldn't wait ... Your description doesn't match what I'm seeing. I have grey, blue and black from both left and right. My nine pin connector is full
  • Britome
14 Feb 2014 19:12 - 14 Feb 2014 19:13
#622292
Ooops
Last edit: 14 Feb 2014 19:13 by Britome.
  • Britome
14 Feb 2014 20:28
#622299
Where is the relay on this bike? This wiring is jacked. I found a mangled junction under the tank. I get the same reading when touching my probes to the green and grey that heads toward the back of the bike.
  • Old Man Rock
  • Old Man Rock's Avatar
15 Feb 2014 05:40
#622325
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
15 Feb 2014 06:05
#622329
Britome wrote: Where is the relay on this bike? This wiring is jacked. I found a mangled junction under the tank. I get the same reading when touching my probes to the green and grey that heads toward the back of the bike.
It sounds like a previous owner has screwed up the wiring. You may need to use the wiring diagram to try to trace out the circuits. On my KZ650-C1 the turn signal flasher unit is behind the left side cover. Ed
