'76 kz750
- bonneman97se
11 Feb 2014 11:58 #621925
by bonneman97se
1976 KZ750 Hacked up bobber project, looking to turn cafe racerish.
Replied by bonneman97se on topic '76 kz750
Schmeck, yes the battery is brand new because the old one was bad. Power is applied to the red/yellow wire to the coil. The actual voltage is 12.7V.
Steell, yes the points are opening and closing. It must just just be the picture making it look that way.
- Schmeck
11 Feb 2014 13:16 #621941
by Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
Replied by Schmeck on topic '76 kz750
If you have voltage from the wire at the points then all I can think of is your point gap isn't right. As for the vw coils. That looks dangerous lol.
- Thank you received: 2098
11 Feb 2014 18:46 #621963
by Patton
Replied by Patton on topic '76 kz750
With contacts open, could use an ohmmeter to assure there's no conductivity between the points spring and the backing plate.
This is to help assure that conductivity to ground through closed contacts is disconnected when the contacts open.
