'76 kz750
- bonneman97se
1976 KZ750 Hacked up bobber project, looking to turn cafe racerish.
- P21
- Thank you received: 34
i had seen them stuck together already and it will never fire good luck
Kawasaki KZ 1000 Police (2002) P21
- Schmeck
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
- loudhvx
- Thank you received: 1616
No. I think what you are seeing as a resistor is actually the symbol for the field coil.bonneman97se wrote: ... it looks like the green wire out of the regulator is attached to the generator through a resistor? is that correct???
The 76 and 77 KZ750B1/B2 share a unique charging system among KZ's. I think they are the only ones to come equipped with a solid-state regulator controlling the ground side of the field coil.
They use an energized field coil to create the magnetic field. The amount of current through the field coil regulates the amount of current generated by the stator. That is how the voltage is regulated.
12v is applied to the field coil through the brown wire on the field coil. The green wire on the field coil is the ground side of the field coil. The regulator controls the current through the green wire in order to control the strength of the magnetism in the field coil, which affects the output of the stator.
The regulator gets 12v power from the brown wire on the regulator. It also uses this wire to sense what the battery voltage is at. The regulator is grounded through the black wire on the regulator. The regulator controls how much current flows through the green wire to ground.
No other KZ's use this system that I know of. Some other KZ' use a similar system, but use a mechanical regulator which controls the positive side of the field coil.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- bonneman97se
Schmeck, checking the points is my next step. The bike has been sitting for more than a year or two, so it is more than possible that the points are stuck.
Loudhvx, now that you state it like that it makes complete sense. I have been refering to all of your diagrams in another thread, and they have been 97% helpful. i understand the way you explained the field coil hookup, but on my bike (i will take a picture when i get home) which wire would i hook the green regulator wire to? There is the one connector with all three sides of the stator, and another connector with some other wiring that is cloth covered,is the wire i need on the engine side of that connector?
I just re-read that and know that it is hard to follow, but, with pictures i believe it will make sense.
Thanks again for all the help/info everyone is providing!
- Schmeck
The picture below was posted to me by Patton when I had problems.
Attachment image_2014-02-10-2.jpg not found
- Schmeck
- bonneman97se
- bonneman97se
- Schmeck
Heres some questions.
Do you have a good battery? Do you have voltage to the wire going to the points when ignition is on?whats the voltage?
- steell
Or just park the points on top of the high point on the points cam and set them.
- Schmeck
