Very Strange Starter Problem, KZ750 twin
  • bountyhunter
  • bountyhunter's Avatar
Re: Very Strange Starter Problem, KZ750 twin
18 Jan 2014 15:16
#619090
Beautiful condition. Must have had some really good care.
  • Topper
  • Topper's Avatar
19 Jan 2014 06:25
#619145
79MKII wrote:
Damn, I wish my 750 twin were that clean! Nice bike.
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
  • Topper
  • Topper's Avatar
19 Jan 2014 06:27
#619146
bountyhunter wrote: Another problem: most of the US bikes have the lights on all the time which throws an extra big current load on the battery when it's trying to start. I rewired mine to disconnect the lights when the starter cranks, extends battery life makes it start better.
Bountyhunter, you got any info on how to perform this mod?
1979 KZ750 Twin
  • 79MKII
  • 79MKII's Avatar Topic Author
  • Love Them Kaws!
19 Jan 2014 10:14
#619165
I'd be interested in that too. I added RH controls with the headlight switch to my MKII and it was alot more complicated than I thought it would be. It's not as simple as finding a single wire and switching it.
The Kaw List:
  • steell
  • steell's Avatar
19 Jan 2014 15:28 - 19 Jan 2014 15:41
#619199
On the 79 twin it's plug and play, on the 80 750 twin you have to cut a wire. The hardest part is removing and replacing the switch pod.
My 79 dressed up as a 80 750G
My first 79 750 twin
I have never had a 750 twin with the rear grab handle, I thought maybe the Indiana air caused them to evaporate :)
Z1 Enterprises sells the chrome headlight bucket and upper and lower chrome gauge covers.
Last edit: 19 Jan 2014 15:41 by steell.
  • bountyhunter
19 Jan 2014 15:36 - 19 Jan 2014 15:38
#619200
Yes. On the 79 750 twin, the main battery power comes in through a 20A fuse then feeds the ignition. After that, there are two 10A fuse branches: one feeds the headlight and some little light and the other line feeds brake lights, horn, other stuff.
I inserted a 10A relay right into each of the two 10A branches so that it was connected normally closed. Then I wired the relay coil off the power line to the starter solenoid so when the starter is cranked, the relays energize and open the normally closed contacts removing all the lights and other stuff, but ignition is still alive.
Last edit: 19 Jan 2014 15:38 by bountyhunter.
  • bountyhunter
19 Jan 2014 15:41
#619202
here is the wiring diagram for my 750 twin, you can see the 20A main line and the two 10A lines that I "interrupted" with relay contacts to open under starter crank.
  • Topper
  • Topper's Avatar
19 Jan 2014 16:14
#619212
Do you do that with a 5 pin relay?
79mkII, don't worry we'll stop hijacking your thread soon.
1979 KZ750 Twin
  • 79MKII
  • Love Them Kaws!
19 Jan 2014 17:55
#619222
No Problem...I'm interested in this too.
So a normally closed relay....I should have thought of that. The problem I had with the headlight switch was I still needed the brake light, tail light, dash lights, front running lights etc... to work while the headlight is off. My switch is a repro of the Z1 switch...it has "off", "on" and "park". It's fine if all of the lights go off while starting...that's a great idea.
The Kaw List:
  • bountyhunter
20 Jan 2014 01:27
#619253
yep, takes five pins. One set of pins for the relay coil, and three pins for the high current contacts (center, NO, and NC)
  • bountyhunter
20 Jan 2014 01:31
#619254
I should probably explain, I used two relays because I only had 10A relays to work with (freebies) so I had to break each 10A branch. You could also use a single 25A relay and break the main line before it splits into two 10A branches. You just need to make sure the ignition coil remains hot (energized) and everything else is downstream.
If your bike has a headlight switch, it would almost surely be downstream from the fuses so a relay could still open everything up heading into the fusebox and not affect the switch wiring.
  • koolaid_kid
  • koolaid_kid's Avatar
20 Jan 2014 03:41
#619256
On a 5 terminal relay, terminal 87 is NO (Normally Open) and terminal 87A is NC (Normally Closed).
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
