battery life effecting kickstart?
- DoctoRot
Re: battery life effecting kickstart?
17 Jan 2014 01:06 - 17 Jan 2014 01:07
Its a 78" KZ650B2 and it DOES have the headlight on/off switch. i thought this was unusual as my 1000 and 750 both had that removed to permanently on. I always turn the lights off when im starting the bike as i have noticed it makes it a bit easier.
bountyhunter wrote:If it's US bike, it probably has the "headlights always on" feature. So you turn the key on to kick start and the lights are dragging down a weak battery and the voltage is too low to fire the coils well. Hence, very hard to start.DoctoRot wrote: Thanks for the replies guys. i had no clue the battery was so important to the electrical system. i knew it acted as a capacitor on the bike but i never figured it would effect starting so much. It makes me realize why they got rid of kick-starters. if its that difficult to kick i usually find a small hill to bump start on. i might have to pick up one of those chargers.
Last edit: 17 Jan 2014 01:07 by DoctoRot.
- koolaid_kid
17 Jan 2014 05:19
The earliest versions of the "Always On" headlight switch were merely the previous switches with a small knob preventing the switch from going to off. A common mod was to remove the knob so the OFF position could be used.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- bountyhunter
17 Jan 2014 13:58
Om my 79, the headlight switch is not even there but the letters molded into the hand grip mounts still there are so you can see the"ON" and "OFF" positions.
- turboking
17 Jan 2014 15:41
I installed a toggle so I can turn off the headlight when starting on my turbo 79 MK II as it has a fuel pump. :dry:
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- steell
17 Jan 2014 18:18bountyhunter wrote: Om my 79, the headlight switch is not even there but the letters molded into the hand grip mounts still there are so you can see the"ON" and "OFF" positions.
If you replace the switch pod with a 78 or earlier, and remove the jumper under the tank so you can plug the switch in, you too will have an on/off switch.
That's all Kawasaki did on the 79, plug a piece of plastic in where the switch goes and jumper the wires under the tank.
