1980 KZ750E Ignition switch/key elimination.
  • Medicontheloose
  • Medicontheloose's Avatar Topic Author
22 Dec 2013 15:56
#616167
Hello all. After a great deal of searching and reading wiring diagrams I need to ask a question.
I want to eliminate the ignition switch/key and install a hidden switch somewhere. Can someone shed some light on how I could go about doing this? I'm still usiing the stock handlebar controls (engine kill switch, start button, etc.) I just want to eliminate the key portion. I've seen people mount switches on the headlight buckets, under the seat, etc.
Thanks in advance for the info.
Sam
"That others may live."
1980 KZ750E
  • Medicontheloose
Re: 1980 KZ750E Ignition switch/key elimination.
24 Dec 2013 17:07
#616333
Has no one installed any sort of toggle to replace an ignition switch?
1980 KZ750E
24 Dec 2013 18:52
#616341
It's not like the old days when the ignition was binary (ON / OFF) switch for one circuit. If you take a look at the switch on your bike I think you will find numerous wires attached to it, so trying to use a simple ON / OFF toggle (as I did on my old BSA) is not as straight forward as it might first appear. Ed
  • MFolks
  • MFolks's Avatar
24 Dec 2013 19:45
#616344
you'll probably need to use several switches,(4 if possible, with some center off positions, to confuse someone trying to hot wire your bike). I'd suggest going to www.watekwire.com or www.delcity.net and look at their marine, or water resistant switches.
  • martin_csr
  • martin_csr's Avatar
25 Dec 2013 09:03
#616371
Here's a site w a manual & wiring diagrams. mbsween.bike-night KZ750L3 page
Scroll down & click "The Bible" link.
Not really applicable to your 750-E1, but some of the wiring diagrams are mislabeled in the links.
An H2 is a 1981 model, the H3 is an 82, & the H4 is an 83. search tags mbsween KZ750L3
  • Lazyman06
  • Lazyman06's Avatar
24 Jan 2014 12:12
#619903
I'm interested in doing somewhat the same thing except i'm not gonna have any control switches at all on mine. Looking at getting one of these
www.racerpartswholesale.com/product/1381...a2l7wCFYNQ7Aod8mIAfw
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
24 Jan 2014 12:55
#619907
Lazyman06 wrote: I'm interested in doing somewhat the same thing except i'm not gonna have any control switches at all on mine. Looking at getting one of these
You plan to eliminate the hi/low lights, turn signals, horn. kill switch, etc? Ed
  • Lazyman06
24 Jan 2014 14:50
#619916
Yep if at all possible. I want a extremely clean bike.
  • KZ-Izzo
  • KZ-Izzo's Avatar
25 Jan 2014 20:29
#620051
ive done this with my bike in the end it is easier to make a new harness as all you need are a couple wires mine is kickstart only so im down to basic ignition module, stator rectifier, brakelight wires and hibeam wire and groundwire
Live Fast
1980 KZ1000 b4 ltd
