Dyna S Electronic Ignition worth it?
  • b0ssdawg
  • b0ssdawg's Avatar Topic Author
Re: Dyna S Electronic Ignition worth it?
25 Dec 2013 03:10
#616355
ok so i think ill stick with points, is kz900.com a good place(38$ inc shipping) and am i able to put new wires on the old coils? or at least make the wires compatible with the new style spark plugs?
Rusty old 1976 kz900
25 Dec 2013 05:42 - 25 Dec 2013 05:44
#616359
b0ssdawg wrote: ok so i think ill stick with points, is kz900.com a good place(38$ inc shipping) and am i able to put new wires on the old coils? or at least make the wires compatible with the new style spark plugs?
If your original spark plug caps do not fit properly on your spark plugs you are using the wrong spark plugs. The caps will fit properly on the correct spark plugs. Using the wrong spark plugs can cause other, more serious problems. What spark plugs are you trying to use? Ed
Last edit: 25 Dec 2013 05:44 by 650ed.
  • Old Man Rock
  • Old Man Rock's Avatar
25 Dec 2013 06:14
#616361
Lou hit it right on the nose..... B)
COILS:
Are they cracked, plug wires real stiff, plug caps cracked/brittle etc...
If you need to splice in a new wire set, then no way you'll get the same results (current path) thus spark to plugs... Just not going to happen...
To add to this, what do they ohm out on the primary & secondaries...?
If out of speck or even close to outer ranges, junk them for just not worth it....
If engine is running, backside of finger on coil after warmed up, can you touch the coil or is it warm or extremely hot to touch...? if real hot, junk them....
As for electronic pick ups, hell I've had mine on now going on 7 years, not one issue....
Bottom line, ignition and drive chains, you go cheap, oh yeah you'll be stranded one day pissed off at your self for not biting the bullet and being too cheap....
Just saying....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • turboking
  • turboking's Avatar
25 Dec 2013 06:29
#616364
+ 1 on dyna ignition and coils.... :) on my mark II turbo I have the old dyna with a box. I've never had any problems with it :woohoo: also have dyna coils and taylor wires..... I've set enough points in my lifetime as you are constantly adjusting them...... :blink: my .02 upgrade to a dyna s
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
25 Dec 2013 09:37
#616376
turboking wrote: + 1 on dyna ignition and coils.... :) on my mark II turbo I have the old dyna with a box. I've never had any problems with it :woohoo: also have dyna coils and taylor wires..... I've set enough points in my lifetime as you are constantly adjusting them...... :blink: my .02 upgrade to a dyna s
___________________________________________________________________
Im running dyna coils with taylor wires also, seems to work good. Don't know why you need all these special wire ends, caps and shit?
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
25 Dec 2013 12:00
#616385
bossdawg, you are just like my niece in law. She and my nephew asked my opinion about buying a house and I told them to stay renting while they save up their hard-earned cash, as did everyone else. What did they do the very next day? Sign a contract on a townhouse that now, in addition to buying house, they were basically spending all the money they spent on rent to go for association fees and well... You have heard good advice from everyone here that have told you the way to go and still you order points. What did you bother asking our advice for if you already had your mind made up to go with PITA points? :S
79 LTD B3
  • BusaMan66
  • BusaMan66's Avatar
25 Dec 2013 14:52
#616394
I've been following this thread as well, and I must say that it has been very helpful. Dyna S it is. Thank you all for your advice.
If you choose not to decide, you still have made a choice. Rush
  • turboking
25 Dec 2013 15:28 - 25 Dec 2013 15:31
#616398
BusaMan66 wrote: I've been following this thread as well, and I must say that it has been very helpful. Dyna S it is. Thank you all for your advice.
don't know if you knew ...... best deal I've seen on flea bay for a new Dyna S
1985 GS 1150E
1983 GS 1100E
Last edit: 25 Dec 2013 15:31 by turboking.
The following user(s) said Thank You: BusaMan66
  • BusaMan66
25 Dec 2013 16:24
#616400
Thanks turboking, I already picked one up yesterday, but appreciate the link, anyway.
  • KZB2 650
  • KZB2 650's Avatar
27 Dec 2013 10:20
#616519
Bought a Dyna S and coils in 1983 and never had a problem till 2004. One of the pickups burnt out then, can't remember but there is a good chance I did this myself by pulling the plug wires and spinning it over while checking comp ?? All I remember is it happened in my shed and not on a ride.
But Anyway after a couple years of messing with points again ( and the bike sitting before the rebuild) I bought a second Dyna, wires and new coils. like the old saying goes its So nice setting it and forgetting it and if I get another 20+ years how can you beat that. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
27 Dec 2013 13:19
#616523
--- probably not, because the stock coils are fitted with permanently affixed plug wires.
Actually, there are aftermarket plug wire "splicers" available which permit attachment of new plug wires onto the stub ends of old plug wires from old original coils.
However, the "splicers" are expensive enough to instead consider replacing the coils with new coils that allow independent plug wire replacements (as they should have been in the first place, imo.).
In any event, stock spark plugs NGKB8ES have serrated tip connectors that fit the stock KZ900 plug caps just fine, as Maw Kaw and GOD intended.
Good Fortune! :)
The following user(s) said Thank You: b0ssdawg
  • BusaMan66
27 Dec 2013 16:26
#616531
No eBay APP ID and/or Cert ID defined in Kunena configurationGood info there, Patton.
So I have received my Dyna S and I'm thinking about going with these coils here, except my Z2 frame allows a 4" coils, and not 3.5":
So, are those 4 ohm coils good enough, or should I go with 3 ohm Dyna coils?
