What do these wires go to on my 78 KZ1000
- HAFROD
19 Dec 2013 22:39 - 19 Dec 2013 22:41
I've spent several hours going through diagrams and all the components. I have everything else labeled and ready to go on. This pic shows THREE single wires and ONE white plastic three prong connector. I do not see what they go to on the diagrams. This is the very forward most section of the Kawasaki harness. The 1st wire on the left is a big double female connector that is BROWN,,,, The 2nd is a three prong connector but only two wires with a orange and a brown wire in the plastic,,,, The 3rd is a black with yellow stripe male connector,,,,, 4th is a brown with white stripe female connector. Help!
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
Last edit: 19 Dec 2013 22:41 by HAFROD.
- Cynjut
Re: What do these wires go to on my 78 KZ1000
20 Dec 2013 07:37
Black with yellow is ground - it's the same (theoretically) as the frame ground. The brown is almost always hot and the brown and white is usually associated with the headlight. The orange/purple one is a mystery.
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
