What the heck is this? 78 KZ1000
  • HAFROD
  • HAFROD's Avatar Topic Author
19 Dec 2013 07:44
#615904
Two 1983 GPz 305's, 1984 GPz550, 1980 KZ550A, 1978 KZ1000A2A
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: What the heck is this? 78 KZ1000
19 Dec 2013 07:46
#615905
The thing with all the goofy connections is the rectifier. It converts the AC output of the stator to DC for the electrical system.
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • HAFROD
19 Dec 2013 08:17
#615908
Will I need this hooked up for a hot wiring? I just want to see if it runs good
  • Cynjut
  • Cynjut's Avatar
19 Dec 2013 08:25
#615910
It converts the AC from the generator to DC. Without it, your electrical system will be using AC. It will, as a minimum, chew up your battery, overheat your coils, and screw up almost anything else that is hooked up. It will also fry your Dyna-S.
I'd say "Yes, you need it,"
1977 KZ-1000 A1
1982 KZ-1000 M2 Frankenbike
  • ZERO
  • ZERO's Avatar
19 Dec 2013 08:47
#615914
I do have a whole harness. I think it's uncut............
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
  • HAFROD
19 Dec 2013 22:28 - 19 Dec 2013 23:32
#615959
How can I test to see if its bad? Or basically, how do I know if its good? Also, it has a black wire coming out of it beside a bit heavier white wire. The black wire is cut. Is this a chassis ground or does it go to something else?
Last edit: 19 Dec 2013 23:32 by HAFROD.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
20 Dec 2013 19:23
#616053
HAFROD wrote: How can I test to see if its bad? Or basically, how do I know if its good? Also, it has a black wire coming out of it beside a bit heavier white wire. The black wire is cut. Is this a chassis ground or does it go to something else?
Search the filebase section of this site for wiring diagrams. There are diagrams for the 78 A2, B2 (LTD), and D1 (Z1r). I see from another post that your bike is a bit of a hybrid.
Based on these diagrams the rectifier should have three yellow wires that come from the alternator, a white wire that goes to the positive battery terminal, and a black wire that goes to chassis ground. On the z1r the black wire is drawn as connecting straight from the rectifier to the chassis. On the A2 and B2 it's shown passing through the 6 pin connector along with the yellow wires. Once through the connector the black wire changes to black/yellow, and runs to the negative battery terminal.
As for testing the rectifier, I can't think of an easy way to do it. Do you have a volt meter that includes a diode test function? This would be a good place to start.
Does anyone have an opinion about what would happen if you just disconnected the alternator stator coil and left it unplugged while running the engine? I was thinking the engine would run fine just on the battery. But I'm worried that leaving the stator coils open/unloaded could cause a high voltage that would damage the stator.
My dad's '74 Z1
'00 ZRX1100
