Ignition Coils
  • oredigger
  • oredigger's Avatar Topic Author
Ignition Coils
17 Nov 2013 17:08
#613293
Alright so while my dad was checking out my bike, he went to take the boot off my spark plug and since it is probably 30 years old and he isn't the most gentle man, he tore up the wiring on it. Now as far as I can tell I am not able to replace just the wire and boot coming from the coil and I need to replace the entire ignition coil. Where can I find one of these coils? Easy to find used? Should I replace both coils or just the one that is obviously broken? I am guessing the wiring in the other is getting weak and my spark on all four have been affected by this..
1980 KZ650-E1 LTD
  • bountyhunter
  • bountyhunter's Avatar
Re: Ignition Coils
17 Nov 2013 17:55 - 17 Nov 2013 17:59
#613295
One coil fires plugs 2-3 and the other fires 1-4. Messing up one should not affect the other.
I have seen kits to put new wires onto old coils, but the wire kits are pricey (like $40 or more).
I am a believer if the coils are original, they should be replaced..... mainly because the grief my old coils gave me.
Not sure what resistance your coils are, but Z1 sells a very good 4 Ohm coil with wires for about $36. I have been running one on my KZ750 for six years, works great.
www.z1enterprises.com/ItemDetails.aspx?i...zuki&item=EM24-72451
Last edit: 17 Nov 2013 17:59 by bountyhunter.
The following user(s) said Thank You: oredigger
  • oredigger
Re: Ignition Coils
17 Nov 2013 18:38
#613303
Thanks for the reply.
Are these coils usually universal? The only difference I can see is the resistance in them, is this the only aspect I need to worry about when searching?
1980 KZ650-E1 LTD
  • oredigger
Re: Ignition Coils
17 Nov 2013 19:12
#613308
No eBay APP ID and/or Cert ID defined in Kunena configurationFound these on ebay...any thoughts?
1980 KZ650-E1 LTD
Re: Ignition Coils
17 Nov 2013 19:37
#613313
What ignition is fitted -- points, igniter, dyna-S?
Good Fortune! :)
  • oredigger
Re: Ignition Coils
17 Nov 2013 22:34
#613321
Patton - I couldn't tell ya...as far as I know they are the stock coils. Are those all brand names that you listed?
1980 KZ650-E1 LTD
  • bountyhunter
Re: Ignition Coils
17 Nov 2013 22:50
#613322
oredigger wrote: Patton - I couldn't tell ya...as far as I know they are the stock coils. Are those all brand names that you listed?
Depending on year and model, some Kaws had point ignitions. Those generally used a four Ohm coil like the one I posted above.
If it had a Kaw electronic ignition with magnetic sensors instead of points, it used lower resistance coils (maybe 3 Ohms?)
If it's an aftermarket Dyna ignition, it probably uses coils in the 3 Ohm ballpark, maybe a shade lower.
  • bountyhunter
Re: Ignition Coils
17 Nov 2013 22:52 - 17 Nov 2013 22:53
#613323
oredigger wrote: Thanks for the reply.
Not universal. If you use a higher resistance coil than stock, won't hurt the coil but may have a little less spark energy.
If you use a lower resistance coil than stock, especially with points, the coil can be killed by excessive heat. It will also draw more current than the system was designed for.
Last edit: 17 Nov 2013 22:53 by bountyhunter.
  • oredigger
Re: Ignition Coils
17 Nov 2013 23:43
#613325
Thanks thats some good info. Been putting in some work on google and this thread kzrider.com/forum/4-electrical/562477-no...nd-or-coil-questions ....hopefully I can figure this out. Thanks fellas!
1980 KZ650-E1 LTD
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Ignition Coils
18 Nov 2013 03:53
#613331
Pull the ignition cover (right side of engine). If you don't have points there you have an electronic ignition. An electronic ignition and the Dyna S ignition use 3 Ohm coils. 4 Ohm coils will work, but as bountyhunter pointed out, the spark will not be quite as hot.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Re: Ignition Coils
18 Nov 2013 04:23 - 18 Nov 2013 04:30
#613334
The parts diagram at kawasaki.com shows 1980 KZ650-E1 LTD having a points ignition.
Many owners have replaced the stock points ignition with an electronic ignition such as the popular Dyna-S electronic ignition.
The above illustration is a KZ900.
KZ650 Dyna-S has another blue wire for the oil pressure switch.
Good Fortune! :)
Last edit: 18 Nov 2013 04:30 by Patton.
  • bountyhunter
Re: Ignition Coils
18 Nov 2013 13:08 - 18 Nov 2013 13:09
#613395
IMHO, the points ignition is adequate if properly working, and is designed to work with standard (cheap) four Ohm coils. The Dyna has some advantages: programmable timing advance, no points to wear or go out of adjustment, supposedly gives hotter spark than stock. Disadvantage is they are pricey, require expensive coils and the Dynas seem to fail without much provocation. The Kawasaki factory electronic ignitions used on some models seem to be pretty durable. YMMV
Last edit: 18 Nov 2013 13:09 by bountyhunter.
