Key is stuck in Park
  • jimmeth
  • jimmeth's Avatar Topic Author
07 Oct 2013 03:26
#609044
Everything's been pretty good with my '82 KZ550. It's my 1st bike. Have had it for a couple of weeks and it's been great other than the new rear tire I need. Then today, after riding it, I switched the key over into "P" (hadn't tried it before) by accident and it got stuck there. The tail light is left on when I pull the key out. If I turn the tail light off, the key is stuck under where it says "push". Can't turn it anymore to the left to reach "on, off, or lock." It feels like the the locking mechanism is jammed (?). Tried graphite key lube to no avail. So now I just have the key sitting in there with the tail light off so I don't kill the battery.
Gonna pull the whole switch out and take it to a locksmith this week. In case that doesn't work out...
Does anyone know if those EMGO switches are as easy to install as they appear to be?
Would it be easier/worth it to find an original ignition switch?
Is there an easier solution I'm missing?
I want to ride as much as I can before the weather turns; need to deal with this soon!
  • lightitup
  • lightitup's Avatar
Re: Key is stuck in Park
07 Oct 2013 04:16
#609046
i get that same problem with my key switch. wat i do is i find the lock part that comes out to lock the steering and push it up while turning the key and it pops back up i can get in there without taking it off
81 kz 550 ltd
  • jimmeth
07 Oct 2013 06:08
#609051
Thanks, I'll give it a shot.
  • jimmeth
07 Oct 2013 15:32
#609141
Well, that didn't work. Pushing on the lock mechanism turned the key but only as far as it was already moving before. Seems like an internal problem inside the key hole,almost as if the key was turned too far to the right and has triggered the Lock mechanism from the other direction, then again, I'm no lock smith. I will be pulling out the ignition tomorrow.
  • rstnick
  • rstnick's Avatar
07 Oct 2013 17:43 - 07 Oct 2013 17:45
#609157
Mine's an older model KZ, a '78, and it gets stuck sometimes when I switch to Park.
Now mine does not have a steering lock incorporated into it, so doesn't need pushing down anywhere.
I am usually able to turn it back to the left by inserting the key all the way, and keep it in all the way, then lifting or lowering the key, trying to manipulate the tumblers, allowing the key to turn.
So far I haven't been stuck.
I'm a Locksmith.
I can cut keys for most bikes, usually doing it by the key code number or duplicating a key.
But I do not take apart ignitions and repair them.
I do not have parts for them, so cannot replace worn or broken parts, which is probably what is causing the problem.
Most ignitions are crimped together, so reassembly could be iffy.
If you are somewhat handy, you can take the ignition apart yourself, carefully, and you may be able to remove a worn tumbler that is jamming, if that's the issue, and get it working again.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 07 Oct 2013 17:45 by rstnick.
  • jimmeth
08 Oct 2013 00:03
#609200
Thanks rstnick, Something to keep in mind. I have fiddled with now so much I'm close to buying replacement switch.
  • jimmeth
18 Oct 2013 01:55
#610420
Welp, you were right the locksmith couldn't help, although they do auto ignition service. Ordered the EMGO KZ ignition which fit perfect and works well. Only thing I will say about it is the key doesn't go in as easy as the original. Finally back on the road!
Thanks for all the suggestions!!!
  • rstnick
  • rstnick's Avatar
18 Oct 2013 16:56
#610479
Spray some Silicone lube into the keyhole, might help getting the key in easier.
Or 3 in 1. WD40 will be dry again in a short time, so avoid that.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
