1980 kz440 sparks, but won't start
  • Nnichols
  • Nnichols's Avatar Topic Author
08 Sep 2013 19:57
#605589
Hey guys,
I haven't ridden my 1980 kz440 LTD in a few weeks, went to start it and it wouldn't turn over. Charged the battery and load tested it, and results were good. When I go to start it, the starter motor spins but the engine won't turn over. I took the plugs out and grounded them against the heads and both plugs sparked. I did a resistance test on the primary coil and got a resistance of 4 ohms. I can't get a resistance measurement across the secondary coil however. Will the plugs still spark even though I can't get a resistance across the secondary coil? Or should I assume the coil is good, since I have spark, and associate the issue with a starter clutch problem?
Any help will be appreciated, thanks!
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 1980 kz440 sparks, but won't start
08 Sep 2013 20:05
#605591
Did you mean the engine would not fire?
Compression, FUEL, spark is what is needed for an engine to fire/run.
Try doing a search on this site on these subjects,lot's of info.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
08 Sep 2013 21:23
#605600
Have you tried bump (push) starting your bike to see if you can get the engine to run? Ed
