Acid Battery Install/ventilation tube 1980 kz650
  • koolaid_kid
  • koolaid_kid's Avatar
Re: Acid Battery Install/ventilation tube 1980 kz650
10 Sep 2013 08:29
#605824
Patton wrote:
Forrest wrote: I am replacing my BikeMaster Acid Battery as of today. I am done with these type of batteries. I am going with a BikeMaster Gel battery. The Gel Battery does not require venting!....
If not already done, would also consider AGM battery (instead of Gel).
Good Fortune! :)
+1 for AGM (Absorbent Gas Mat). Gel batteries, while better than lead/acid, are still one generation behind the current AGM battery. AGM is presently the best out there for the price.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
The following user(s) said Thank You: danpcali
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
10 Sep 2013 15:53
#605860
danpcali wrote: I will post a picture later on today of how I rearranged the placement of my vent tube. Forest brought up some good points and since I am modifying my bike into a cafe racer it might be best to go w a smaller more modern battery. A smaller battery would allow me to open up the space between the rear tire and the engine giving my bike more of a cafe look...but that's a topic for another thread I think.
You are most certainly welcome Dan. If I was opening up space and looking for weight savings, the Lithium Ion battery. They are the lightest, 4 lbs and smaller. Cost is higher but that may be secondary for the Cafe look and performance.
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
10 Sep 2013 16:00 - 10 Sep 2013 18:11
#605862
Good Fortune! :)
Absorbant Glass Mat(AGM) is good and maybe better weight wise over Gel but here is something to consider: Gel cells be can damaged such as in a crash or even be drilled through and they will not leak or fail. The battery will still work. AGM batteries still contain acid and if damaged could fail and leak acid. I want to avoid the dreaded acid leak going forward.
Otherwise, they are both equivalent. For my more modern bikes or special projects, I am going to go Lithium Ion as the #1 choice when replacing.
Last edit: 10 Sep 2013 18:11 by Forrest.
  • martin_csr
  • martin_csr's Avatar
10 Sep 2013 16:23 - 10 Sep 2013 16:27
#605866
Last edit: 10 Sep 2013 16:27 by martin_csr.
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
10 Sep 2013 18:06
#605880
That there be some low priced AGM batteries! That is the price of a traditional battery! :ohmy:
  • danpcali
  • danpcali's Avatar Topic Author
  • I ride a 1980 kz650e
10 Sep 2013 21:41
#605908
Here is what I did with the vent tube...look good?
10 Sep 2013 21:51 - 13 Sep 2013 13:54
#605911
That should work, I see you found that loop ion the battery box. Originally, the vent tube ran in front of the swing arm between it and the engine at the same place the carb overflow tubes run. If you have a longer piece of tubing you may want to route it there. Ed
Last edit: 13 Sep 2013 13:54 by 650ed.
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
11 Sep 2013 17:36
#606050
danpcali wrote: Here is what I did with the vent tube...look good?
Looks Good! Better than fitting on your swing arm grease nipple! :ohmy:
Go with what Ed says. If the vent tube is cut too short, has a hole burned in it, etc. then replace. That is if you have an liquid acid base battery that requires venting.
Just picked up my Gel battery today. $88 with sales tax! :) Let the Gellin begin! B)
  • danpcali
28 Sep 2013 23:16
#608163
Forrest
Where did you get your gel battery for $88? My battery is crapping out on me
  • martin_csr
29 Sep 2013 10:24 - 29 Sep 2013 10:25
#608201
You should route it in front of the swing arm... the same as the other tubing.
Last edit: 29 Sep 2013 10:25 by martin_csr.
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
30 Sep 2013 14:02
#608348
danpcali wrote: Forrest
Hey Dan, Got it from my local gear/supply guy, Racer Cafe. www.racercafe.com . I am in the Chicago, IL area. Not sure of your location. I am guessing "cali" stands for the state of CA. :unsure: My local supply guy offers some really good deals. This particular battery is a Bikemaster Brand Gel. Hope you can find a deal too! Feel free to contact Eric at Racer Cafe if he can help.
