Acid Battery Install/ventilation tube 1980 kz650
- danpcali
- I ride a 1980 kz650e
08 Sep 2013 08:38
Nood here. Just bought my first bike ever (1980 kz650 LTD). I bought the bike from its second owner. The bike runs strong but not a lot of routine maintenance was done to it.
As I was checking the charge of the acid battery installed by the second owner, I noticed that the battery ventilation tube was pinched and crammed into the battery box. I read an installation guide regarding acid batteries and it said to make sure that the ventilation tube isn't pinched preventing gas from escaping due to the fact that if the gas isn't allowed to vent properly the battery could explode.
I checked my Clymer manual and nothing was mentioned about the ventilation tube. I did my best to re-install the battery and make sure that the tube wasn't pinched. As I was doing so, I noticed what I will call a "valve stem" on the base of the frame of the bike that was positioned close to where the ventilation tube ended when I uncoiled it.
What it this "valve stem" for? Can I hook my ventilation tube into it (like in the picture I provided)? Will I be compromising the battery by doing so?
How do you guys have your ventilation tube positioned?
- P21
Re: Acid Battery Install/ventilation tube 1980 kz650
08 Sep 2013 09:24
i use AGM batterys
just as long as it can vent dont block off end of hose let it hang or tie wrap it
Kawasaki KZ 1000 Police (2002) P21
The following user(s) said Thank You: danpcali
- P21
08 Sep 2013 09:25
welcome to the nut house!
- JR
08 Sep 2013 09:29
That nipple on the swing arm looks like the grease nipple for greasing the swing arm. It's a little different on my 750 but I'm pretty sure that's what it is. Run the the battery vent tube between the swing arm and the motor just forward of where you have it.
It's good to have the vent tube connected as it prevents any acid falling on the electrics. I never heard of the possibility of explosion due to a pinch. I would think any gas pressure would pop off a pinched tube but then I'm no expert.
08 Sep 2013 10:54
The battery vent tube should attach to the right side of the battery (see 1st pic). From there it drops straight down through a small loop welded to the outer edge of the battery box (you should be able to see this loop with the side cover removed and the seat open). After it passes through the loop, it drops straight down and then slightly forward so it extends between the front of the swing arm and the rear of the engine. It should hang down toward the ground 2 or 3 inches below the engine. Second pic shows where it goes behind the right side cover. Ed
Attachment 00002_2013-09-08.jpg not found
Attachment 00001_2013-09-08.jpg not found
08 Sep 2013 11:42
Sometimes the vent tube doesn't get routed right & you end up with battery stains on the muffler chrome.
- danpcali
09 Sep 2013 08:43
Thanks guys, much appreciated!
- KZB2 650
09 Sep 2013 12:02
I've been using a small asprin bottle taped on the end of this tube with cotton balls and baking soda in it to keep the acid drippings from staining the wheel, header etc.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
09 Sep 2013 15:59KZB2 650 wrote: I've been using a small asprin bottle taped on the end of this tube with cotton balls and baking soda in it to keep the acid drippings from staining the wheel, header etc.
That's not necessary if you route the tube properly and let it hang down a couple inches below the bottom of the engine. Ed
- Forrest
- The Mad Duck
09 Sep 2013 16:31 - 09 Sep 2013 16:33
I am replacing my BikeMaster Acid Battery as of today. I am done with these type of batteries. I am going with a BikeMaster Gel battery. The Gel Battery does not require venting! Yes, it is more $$. I am 99.99% sure my old battery(3 years old BTW) crapped out with a bad cell while on my way to the Cycle World Rolling Concours at the Indianapolis Motor Speedway(IMS). The extra $$ seems inconsequential at a moment like that. AND, The cranking power is better and reliability should be improved. Also, Acid batteries may become harder to find in the future due to Eco/Regulatory reasons. Gel batteries are now old technology with Lithium Ion(also,no venting) being the latest greatest. If I was replacing in my more modern sportbikes, then I would go Lithium Ion. For these old steeds, I will be "Gellin" from now on.! :silly:
Basic pricing info on the three types of batteries:
Traditional Acid Type Battery..... $50-$60.
Gel Battery.......................$100
Lithium Ion Battery...............$150
Last edit: 09 Sep 2013 16:33 by Forrest.
- danpcali
10 Sep 2013 06:52
I will post a picture later on today of how I rearranged the placement of my vent tube. Forest brought up some good points and since I am modifying my bike into a cafe racer it might be best to go w a smaller more modern battery. A smaller battery would allow me to open up the space between the rear tire and the engine giving my bike more of a cafe look...but that's a topic for another thread I think.
10 Sep 2013 07:14 - 10 Sep 2013 07:15Forrest wrote: I am replacing my BikeMaster Acid Battery as of today. I am done with these type of batteries. I am going with a BikeMaster Gel battery. The Gel Battery does not require venting!....
If not already done, would also consider AGM battery (instead of Gel).
Last edit: 10 Sep 2013 07:15 by Patton.
