Modern Kaw electrical connectors
28 Aug 2013 10:06 - 15 Nov 2013 07:26
Does anyone know where to get electrical connectors that are an exact oem match to modern Kawasakis?
I already have a long list of places that sell electrical connectors, so I know there are a million places to check, which I've already been doing & it is a big pain in the you know what. So if anyone knows exactly where to look, that would be a big help. Thanks.
Last edit: 15 Nov 2013 07:26 by martin_csr.
- Motor Head
Re: Modern Kaw electrical connectors
28 Aug 2013 10:32
Which connectors, got pictures, are they for your CSR? Insulators and terminals?
28 Aug 2013 10:44 - 28 Aug 2013 11:35
I'm planning on installing a Ninja 250 voltage regulator onto my 81 650 & need the matching connector. The reg-rec on my bike may be bad & the wire harness connector for it is crumbling. When installing the Ninja part, it would be handy to replace my crumbly connector w one that mates to the ex250 connector.
07 Kawasaki Ninja EX250 F Voltage Regulator EX 250F 250R Rectifoer
Last edit: 28 Aug 2013 11:35 by martin_csr.
28 Aug 2013 14:12
Take a look at the connector on the far right in the second row (labeled B-13). I'm not sure, but that may be the same as the one shown in the eBay listing. You may want to contact HVCCyle and ask if the next one (B13-R; far left - third row) is the corresponding half of that connector. Ed
www.hvccycle.com/electrical-connectors.html
28 Aug 2013 15:11
Those were among the first ones I checked. The B-13 locking tab seems to be different. I guess I'll try the Kawasaki dealer. Melted connectors aren't all that uncommon, so maybe they have something? fingers crossed.
- StreetfighterKz
28 Aug 2013 15:41
I worked at a dealership that carried the big Japanese four. I don't recall ever seeing the OEM's sell separate connectors. They may have as part of a recall, but not part of a normal microfiche.
Your best bet may be to order an aftermarket set of both male and female connectors and replace both sides.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
28 Aug 2013 15:49
I guess if a connector melts, a dealer will replace the part & the wire harness, hence no spare connectors?
- StreetfighterKz
28 Aug 2013 15:57martin_csr wrote: I guess if a connector melts, a dealer will replace the part & the wire harness, hence no spare connectors?
Pretty much..
Check out Namz . Parts Unlimited carries some of the connectors but not all. They cater to the HD crowd but have metric OEM style connectors as well. I've ordered several connectors using eBay and had good luck with them on hand switch control swaps but those are normally lighter gauge wires.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- loudhvx
28 Aug 2013 18:21 - 29 Aug 2013 03:07
If all else fails, you could try these.
They look to be similar if not the same.
You can get boths connectors, and 10 of each terminal, for less than $10.
www.z1enterprises.com/ItemDetails.aspx?i...%29&item=KL34-1853-1
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 29 Aug 2013 03:07 by loudhvx.
- Motor Head
28 Aug 2013 23:15 - 29 Aug 2013 00:03That is actually a super common connector in the Jap Car industry. Anything in the 80's will have that. Usually found at the Load Reduction Relays, also Fuel Pump Relays etc. The voltage regulators on the 70's Jap cars used it also, Male and Female. A trip to the wrecking yard, a set of wire cutters and you'll have a match for Cheap if they charge you at all.martin_csr wrote: I'm planning on installing a Ninja 250 voltage regulator onto my 81 650 & need the matching connector. The reg-rec on my bike may be bad & the wire harness connector for it is crumbling. When installing the Ninja part, it would be handy to replace my crumbly connector w one that mates to the ex250 connector.
Last edit: 29 Aug 2013 00:03 by Motor Head.
- Haybus
- Big Al
29 Aug 2013 02:30
I asked Z1 Enterprises about the stock regulator and rectifier connector/pins and this was their reply:
Alan,
Those pins, which we've spent hours searching for, seem to be both Kawasaki
proprietary, and highly guarded.
We purchase stator assemblies out of Japan that include a 6-pin connector
that plugs into the existing electrics. So someone, somewhere, is
manufacturing the pins. Unfortunately, we can't find that someone.
I wish I had a better answer for you.
Kindest regards,
New! Check us out on Facebook!
Z1 Enterprises ~ Facebook
Christopher B. Baker <>< ("Bakes")
Z1 Enterprises, Inc.
I would bet that's still common with modern Kawisaki bikes.
Alan,
Kindest regards,
1976 KZ900 LTD (sort of)
2005 FJR
2009 Hayabusa
www.kzrider.com/forum/11-projects/557845...-streetfighter-build
2005 FJR
2009 Hayabusa
15 Nov 2013 08:03
I ended up installing the Ninja 500 voltage regulator using connectors from CycleTerminal.com. The Sumitomo .250 6-pin locking connector was an exact match for the Ninja connector, and the Sumitomo connector does actually physically fit the KZ connector, but unfortunately the Ninja & KZ wire harness connectors both have female terminals - they don't mate. So I cut off the Ninja terminals, then installed new male terminals & a new Sumitomo connector set. I also installed a medium sized connector cover (from cycleterminal).
