Headlight stopped working
08 Aug 2013 23:30 #600517 by TroLLz
Headlight stopped working was created by TroLLz
I have an 81 Kz440 ltd that I purchased recently this is my first bike and im slowly trying to turn it into a cafe bike. Earlier today I was tinkering around and decided to delete my blinkers back ones came off fine but the fronts I had to cut but when I turned the key back on the headlight stopped working I looked into it and it doesnt look like its burnt out. So I need another opinion on this.
08 Aug 2013 23:39 #600520 by MFolks
Replied by MFolks on topic Headlight stopped working
Find your fuse block/box, most fuses are in a plastic enclosure, one or more of the glass tubes fuses may be bad. Most auto parts stores can get you the AGX size fuse. I'd imagine 10 amp will be the size.
The next step will require the use of a multimeter to check the voltage at the headlight electrical connector. There are three(3) prongs, one is the ground(Black with yellow stripe) the others are high, and low beam. If you get voltage at the prongs, the headlight may have burned out.
If you have questions about using a multimeter, post back.....
08 Aug 2013 23:57 #600522 by 650ed
Replied by 650ed on topic Headlight stopped working
Hacksawing off turn signals, while certainly creative, is not necessary to remove them as they are not actually welded onto the bike. So sawing through the wiring, if that's what you did, may have contributed to your electrical problems. A starting point may be to take a look at any wires you chopped off to see where they run and what they were connected to before you cut them. Ed
09 Aug 2013 00:35 #600532 by TroLLz
Replied by TroLLz on topic Headlight stopped working
650ed wrote: Hacksawing off turn signals, while certainly creative, is not necessary to remove them as they are not actually welded onto the bike. So sawing through the wiring, if that's what you did, may have contributed to your electrical problems. A starting point may be to take a look at any wires you chopped off to see where they run and what they were connected to before you cut them. Ed
On the front turn signals only the negative wire comes off but the positive wire is impossible to get to so I had to cut it. Also both front blinkers are wired to the headlight long with everything else but I half ass wired them back up and got all blinkers working again and headlight still didnt work
09 Aug 2013 01:00 #600535 by btchalice
Replied by btchalice on topic Headlight stopped working
probably lost the ground when you removed the front turnsignals
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
09 Aug 2013 10:47 #600578 by martin_csr
Replied by martin_csr on topic Headlight stopped working
TroLLz wrote: On the front turn signals only the negative wire comes off but the positive wire is impossible to get to so I had to cut it. Also both front blinkers are wired to the headlight long with everything else but I half ass wired them back up and got all blinkers working again and headlight still didnt work
The front turn signal (+) wires probably have bullet connectors inside the headlight bucket.
  • WABBMW
  • Let The Good Times Roll !
09 Aug 2013 18:35 #600620 by WABBMW
Replied by WABBMW on topic Headlight stopped working
TroLLz:
Martin_csr is exactly right. There are connectors inside the headlight housing that go to the turn signals. The parking light wires are grey on one side and green on the other (I can't remember which is which). then there are turn signal wires that ate a light blue and another color on each side. When you cut the wires, you most likely caused a short and blew a fuse. Unplug these wires inside the headlight housing and replace the fuse. I'll bet the headlight will work again.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
09 Aug 2013 18:54 #600624 by MFolks
Color Codes On Most Kawasaki’s (written for 1980’s bikes)
HEADLIGHT
RED with BLACK stripe, High Beam.
RED with YELLOW stripe, Low Beam.
BLACK with YELLOW stripe, the ground circuit.
BRAKE/TAIL LIGHT Can be an # 1157 dual filament bulb
RED, Running or Tail Light.
BLUE,(sometimes with a Red stripe) Brake Light Circuit.
LEFT FRONT TURN SIGNAL Can be an #1157 dual filament bulb
GREEN, Left front turn signal circuit.
BLUE, Left front running light circuit.
RIGHT FRONT TURN SIGNAL Can be an # 1157 dual filament bulb
GREY, Right front turn signal circuit.
BLUE, Right front running light circuit.
LEFT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREEN, Left rear turn signal circuit.
RIGHT REAR TURN SIGNAL Can be an #1156 single filament bulb
GREY, Right rear turn signal circuit.
09 Aug 2013 19:17 #600625 by TroLLz
WABBMW wrote: TroLLz:
ok i seem to be having a hard time locating the fuse box all i can find is somthing like this
Attachment KGrHqVHJEgE-mlRcq2BPwYu1OTw60_35.JPG not found
but it dosnt open, unless there is another fuse box im missing
09 Aug 2013 20:25 - 09 Aug 2013 20:27 #600630 by koolaid_kid
Replied by koolaid_kid on topic Headlight stopped working
That looks like it. There should be 3 glass fuses inside it.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
Last edit: 09 Aug 2013 20:27 by koolaid_kid.
09 Aug 2013 23:51 #600645 by TroLLz
ok so its not exactly that but its a black box that looks like that but has no way to open
  • Motor Head
10 Aug 2013 00:00 #600649 by Motor Head
Replied by Motor Head on topic Headlight stopped working
You Factory Service Manual for your Bike. It will show you a lot of info, including where fuses are located and the correct amperage rating for each one.
