Electric start wont work
  • smjohnston88
  • smjohnston88's Avatar Topic Author
03 Aug 2013 11:30 - 03 Aug 2013 11:33
#599678
I tested all the power wires going through the bike and the switch and the starter are getting power and not turning. The starter worked before I switched my bars. I was wondering if anyone could help me resolve this problem.
Last edit: 03 Aug 2013 11:33 by smjohnston88.
  • MFolks
  • MFolks's Avatar
Re: Electric start wont work
03 Aug 2013 12:55
#599683
Starter Solenoid/Motor Checkout Procedure
Some simple steps to determine what is working and what's not:
1.Fully charge and test the battery(most bike shops can load test the battery), and then use a floating ball hydrometer to check specific gravity in the charged cells.
2.Clean all battery terminals of corrosion.
3.Tighten all starting related connections(Positive RED(+) battery terminal, Negative BLACK(-)terminal) and from the terminal to the engine case. All connections must be clean and tight. If the cables feel “Crunchy” when flexed, they may have corrosion inside the insulation, requiring replacement.
4.Clean the cable from the starter solenoid to the starter motor.
5.Clean and check the "bullet connectors" going to the coil side of the starter solenoid.
6.Try again to start the bike, keep in mind some Kawasaki’s have a clutch interlock to prevent cranking the engine while it’s in gear, so the clutch lever must be squeezed.
7.If no luck, go to step #8
8.Wearing eye protection, bridge with pliers or a screwdriver the two heavy duty(large)terminals on the solenoid. If the bike cranks, your solenoid may be bad.
9. If the starter won’t turn over, one of several things has happened; The starter motor has seized due to brushes binding up, lack of lubrication in the bushings of the motor, the battery is weak , the engine has seized or it could be a combination of any of the above. Some websites for starter motor rebuild kits are:
A. www.mawonline.com/newsite/rick_s_motorsp...-starter_brushes.htm
B. www.psep.biz/store/mitsuba_starter_motors_page_2.htm
10.The dealer may want $$$ for a new solenoid, but take your old one along and visit the nearest riding lawn mower shop. They have solenoids for about $15 that with a little work will fit. Be aware that the new solenoid from the lawn mower shop may require a ground wire for it to work.
11. I’d recommend upgrading from the existing battery cables to at least 6 gauge welding cables.
They are available in two colors(RED and BLACK) have more flexibility due to being constructed with finer conductors, and will fit in tighter areas.
12. The welding cable is sold by the foot, so take careful measurements or bring your old cables along. Most battery shops might be able to supply the cable too, so call to find out. The battery shop should be able to crimp/swage on the end of the welding cable the terminal ends or lugs using either a dedicated crimping machine or a tool that looks like a bolt cutter that has special dies to terminate the cable.
The following user(s) said Thank You: smjohnston88
  • Brad Pitt
  • Brad Pitt's Avatar
09 May 2015 04:46
#671221
Similar yet different issue. My electric start isnt working but its not dead of seized...instead is just makes a whirring or spinnjnh noise from under the left side/clutch cover. Any tips on where to start ?
77- KZ1000
76-RD400
74-RD250
73-RD350
73-RD200
73-RD60
72-CL350
72-LS2
71-G3TR
71-CL350
  • SWest
  • SWest's Avatar
  • 10 22 2014
09 May 2015 04:55
#671223
Yes. It may be a problem with the starter clutch. If that component fails the starter will spin but the engine won't turn over. You may want to use the search engine on this site to do some initial research to see if others reported and repaired problems that had the same symptoms you are experiencing. Ed
