battery maintainer reviews.....
  • turboking
  • turboking's Avatar Topic Author
20 May 2013 10:24
#588323
what brand and model of battery maintainer have you used.....let me know all the good and bad :evil: lol......
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
  • richrand
  • richrand's Avatar
Re: battery maintainer reviews.....
20 May 2013 10:41
#588325
Battery Tender Junior. I have only used it for a year now. Worked as advertised and is small, simple, and inexpensive (got mine from Amazon for about $23).
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
20 May 2013 13:33
#588348
I also use the Battery Tender Junior. I've had it for 6 months. Works great, cheap, simple. I couldn't ask for more. I liked it so much I bought a second unit.
The Battery Tender Plus (~$50) is temperature compensated, while I believe the Junior is not. The temperature compensation might help to prolong battery life in very hot or cold temperatures. However, given the short life/low quality of the motorcycle batteries I've owned, I don't think it would make a difference.
Using the Junior has allowed me to avoid replacing my aging battery, which was not starting the bike very well. I started using it when I noticed the battery was getting weak, and now the bike starts great. It may also be that my charging system isn't 100%. But either way, the battery tender is making it work.
My dad's '74 Z1
'00 ZRX1100
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
20 May 2013 16:40
#588384
here is the one i have.
www.salesavo.com/avo.php/SalesAvo/pd7116.../Maintainer_by_Yuasa
no muss no fuss does what it is supposed to.
  • martin_csr
  • martin_csr's Avatar
20 May 2013 16:45
#588386
Someone mentioned a CTek charger on another forum a while back, but I have no first hand info about them.
CTEK Battery Chargers
  • turboking
21 May 2013 09:29 - 21 May 2013 09:31
#588484
[IMG
:evil: Okay here is my nightmare with Deltran Battery tender pluses....... :huh: I had a real old one which the transformer burnt out....... so I thought I would replace it with the same unit :pinch: I purchased 3 of the Battery Tender pluses from chaparral....all have their 10 year (so called) warranty :evil: the first one lasted about 12 months then would NOT go to float mode and torched a relatively new battery.burnt it up, cooked it, toast.... sooooo i opened the second and put it to another new battery(cooked battery replacement).
it worked a little over a month and would not go back into float mode........ :pinch: spotted this quickly and removed the evil charger before it could do damage...... :evil: opened the 3rd and it worked a little over 2 weeks..same deal won't return to float....battery is fully charged....tested with a hydrometer.....no bad cells. yada,yada, yada....... :( ...... my schumacher maintainers and craftsman maintainers have worked flawlessly.
I contacted Deltran by phone ......their tech could not understand the issue......which is b.s. as I found more people having(cooked batteries) the same problem via the internet :pinch: :pinch: If I send them back to deltran they will check them out and if no problem is found ,I will be charged $10 each, service fee plus shipping both ways :evil:
I did some more digging and found that Deltran doe not repair them they REPLACE them with new units......some so called repair.
So I will be sending three of these high priced trash chargers back. when I get the replacements I will put them on E bay and recoup my money for this junk :whistle: .lol they will be unused :huh:
1985 GS 1150E
1983 GS 1100E
Last edit: 21 May 2013 09:31 by turboking.
  • Motor Head
  • Motor Head's Avatar
21 May 2013 09:44
#588489
For $5 when on sale, the Harbor Freight Float Charger works good. I wire it with a male power socket end, and the bike with the female, and just plug in when the bike will sit during winter. Plug it it for a day, once a month. My battery is only 3 years old, but so far so good.
  • TexasKZ
  • TexasKZ's Avatar
15 Feb 2014 07:09
#622334
These look really interesting, but all the ones I looked at require 240v input. Anybody know of one that uses 120v in?
martin_csr wrote: Someone mentioned a CTek charger on another forum a while back, but I have no first hand info about them.
  • TexasKZ
  • TexasKZ's Avatar
15 Feb 2014 07:22 - 15 Feb 2014 07:23
#622335
Ok, somebody must be frying my bacon in crack juice. I just went back to the website and see nothing in the specs about input voltage, and I zoomed in on the pick of the charger and the lable clearly says 110-120v.
Last edit: 15 Feb 2014 07:23 by TexasKZ.
  • pete greek1
  • pete greek1's Avatar
15 Feb 2014 09:01
#622339
I bought a ctech battery charger a couple of years ago & I love it, they call them smart chargers, because once your battery is fully charged it stops charging & starts charging again when needed, I learned my lesson with a battery tender when my bike was out of commission for a couple of years & had the battery hooked up to a tender, just to find out it completely fried the battery, because they never stop charging, ctech is a little pricey, but cheaper than a new battery & they have different setting for car batteries & they are completely weather proof from rain or snow ...Pete
  • turboking
15 Feb 2014 09:50
#622343
No eBay APP ID and/or Cert ID defined in Kunena configurationhere is the replacements for the DELTRAN battery tender pluses that I bought ....i have 3 of these now.... :lol:
I brought a couple of car batteries back from the dead with this charger :evil: ....... people discard /replace batteries that are still usable ......yes, if the battery is too far gone it can't be brought back to 100 % charge...... we as consumers are being scammed , buying tenders and such as they do not de-sulfate the battery plates......sulfation of the plates is the # 1 killer of lead acid batteries :S
after using the xtreme charger my hayabusa turbo's battery spins the engine like the spark plugs are missing..... B)
before I bought the xtreme charger my 4 year old Bandit 1200 S battery (agm) seemed like it was going away even though I use a maintainer religiously :blink: I got the dreaded solenoid click :S ......SSSSSSSSSSSo i got my 1st extreme charger and hooked it to the bandit. the battery had 25% charge showing on the xtreme charger....... it steadily got higher, 50%, then after 3 days of being connected 75%.
after about a week 100% charge. at first, it did only hold the 100% for a couple of days ,then drop to 75%.
needless to say I left the battery hooked to the charger "full time" and after a couple of weeks charging it's holding the 100% charge .....the battery now spins the engine like the plugs are missing....I checked the battery on my pricey small engine battery load tester and now the battery tests as "GOOD".
I'm sold on these and have since bought 2 more.... ;)
as costly as batteries are now , my xtreme charger has more than paid for itself......extending my batteries life. ;)
1985 GS 1150E
1983 GS 1100E
  • peter1958
  • peter1958's Avatar
15 Feb 2014 09:59 - 15 Feb 2014 10:00
#622344
I use a ctek and have never had any problems. I bought it because loudx or whatever his name is said it was good and it is
Last edit: 15 Feb 2014 10:00 by peter1958. Reason: gh
