Timing advance help
- Jrbrownie00
Timing advance help
06 May 2013 21:58
So I have both a kawasaki and Haynes manual and while they tell you how to take these apart, it's not clear to me exactly what's supposed to move and where I'm supposed to put lubrication. Is the middle portion supposed to rotate inside the rotor portion? Where do I lube?
The bike is an 82 kz750 Ltd.
82' kz750 ltd.
Re: Timing advance help
06 May 2013 22:11 - 06 May 2013 22:17
Regardless of the rotor type (points style is pictured), lube the weight arm pivots.
Stock ignition has a slightly pointed rotor. Dyna-S has a round rotor.
Should be able to lube the pivots by accessing through the timing window.
Stock rotor
Dyna-S rotor
Stock rotor
Dyna-S rotor
Last edit: 06 May 2013 22:17 by Patton.
- Jrbrownie00
06 May 2013 22:16
Your awesome Patton. Thanks. I looked ok google and didnt see any of that info.
82' kz750 ltd.
06 May 2013 22:17 - 06 May 2013 22:18
Your timing advancer should be very similar to the one on my 81 650-CSR, so you should be able to separate the rotor from the advancer body. It takes a little dexterity, but just twist the rotor then pull it off. There should be a groove - if so, the manual says to fill it w grease. Lube whatever moves.
Last edit: 06 May 2013 22:18 by martin_csr.
- Matteson
06 May 2013 22:27
when I pulled the cam off and put the new dyna magnet cam or whatever you call it on I put some grease on it then slid it on. Did I lube the wrong part?
KZ 900-a4
06 May 2013 22:37 - 06 May 2013 22:38
Isn't the Dyna rotor one piece w no moving parts? I don't think it needs lubrication. not sure, though.
Last edit: 06 May 2013 22:38 by martin_csr.
