another kz400 problem .electrical
- recez
- 74 kz400 D
06 May 2013 17:37
I was riding down the road everthing is going fine. I hit a little rough patch of road and now all my electrical intruments are gone. I oviously sounds like something came loose... but I'm not seeing anything jump out... I did look at the little fuserbox and the fuse looks rough but would that cause all lights, turn signal, brake lights even the oil and neutral light are not working. Electric start does nothing.
the bike will fire up with the kick starter so I'm get spark. Any suggestions as to where I should look?
74 kz400 D cafe
- recez
- 74 kz400 D
Re: another kz400 problem .electrical
06 May 2013 17:51
could this little fuse be the source of my problems. The fuse is broken in the middle... but there's this little bit of sider right under neath the break in the fuse. Does this fuse run all my instruments? Lights etc?
74 kz400 D cafe
06 May 2013 18:15
Replace the fuse. All the fuses in the fuse holder are needed for everything to work. Ed
- recez
- 74 kz400 D
06 May 2013 21:04
thanks ed... yep it was that fuse
an easy one finally
74 kz400 D cafe
- MFolks
06 May 2013 23:37
I make a habit of replacing the glass tubed fuses each year. Read this about the fuses:
Fuse And Fuse Holder Designations
1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
4. These fuses can fail internally but look good, only by using a multimeter to check for voltage going through the fuse, or when the fuse is removed for physical inspection for tight end caps & continuity checks, can it be determined if it’s serviceable.
5. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
6. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
7. If the fuse and fuse holder overheat, it could soften or anneal the grip of the clip, it might require squeezing the clip to restore the tightness.
8. A list of where to purchase “Blade” style fuses and holders:
www.waytekwire.com order.waytekwire.com/productdetail2/M50/...20%20%20%208%20FUSE/
www.rallylights.com www.rallylights.com/detail.aspx?ID=765
www.delcity.net/store/6!way-fuse-blocks/p_10822.a_1
www.easternbeaver.com/Main/Elec__Product...ers/fuseholders.html
www.autowiringsolutions.com/item.php?item_id=251&category_id=89 (ATO/ATC Fuse Holder)
9. A source for the glass tubed AGX fuses:
www.boatownerswarehouse.com/browse.cfm/2,4986.html
- bountyhunter
07 May 2013 03:46Amen. If the fuse wire looks at all discolored or bent, replace IMMEDIATELY.MFolks wrote: I make a habit of replacing the glass tubed fuses each year.
- loudhvx
07 May 2013 11:48
It's possible the fuse blew because there was a brief short when you hit the bumps. You may want to eventually make a closer inspection of the wiring, especially near the steering area.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- recez
- 74 kz400 D
10 May 2013 02:27
thanks for the help guys. sorry for the late reply, was out of town for a couple of days. Loudhvx ,this did happen after I messed around with a little wire (ground wire maybe?) that was running from under the gas tank into the head light... But what made me mess with it was the fact that it was spliced right near the handle bars and twisted together (without a wire nut or tape mind you) just sitting there. I sort of pulled on it and it came out of the head light like it wasn't connected to anything (no resistance when I pulled it). This is the thinnest wire On the bike, is this a ground wire and should it be connected in the headlight? Why might it have been spliced? Maybe because there was a front windsheild on it at some point.
Mfolks.... Thanks a bunch for the info. I'll definitely clean the fuse clips as you stated. I did manage to find some fuses that work at the local hardware store. But That fuse box seems to be getting really hot... but that might be a result of it not being grounded..as I stated above
74 kz400 D cafe
- loudhvx
10 May 2013 10:21
Shorting a ground wire won't blow a fuse. I would look for power wires. Brown wires would be the first suspects.
1981 KZ550 D1 gpz.
Other links.
Other links.
- CoolerKing
10 May 2013 10:36 - 10 May 2013 10:36
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you decide to "upgrade" your fuse box. Check out newer used ones on ebay. I snagged this 3 fuse box from a Honda Shadow that I'm planning on using on my new build
1978 KZ650-C2
1976 KZ400D-3 (sold)
Last edit: 10 May 2013 10:36 by CoolerKing.
- recez
- 74 kz400 D
11 May 2013 00:01
Ok.. I will look for suspect power wires. And the new fuse box looks like a good idea for an upgrade... thanks for the suggestions
74 kz400 D cafe
