Help Please - Simple Wiring Diagrahm
  • odl666
  • odl666's Avatar Topic Author
09 Feb 2013 22:49
#571668
Attachment NewWiringDiagrahm-2-9-13.png not found
Hello!
Please see the attached picture, can you please help me conect the dots? I completed the wirng on the bike but it is not working right????? i think I musunderstod the ingnition switch since it has 6 wires.
CAn some one help me connect the dots on the attached file?
1978 Kawasaki kz650b2
Thank you1
Mark
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Help Please - Simple Wiring Diagrahm
09 Feb 2013 22:57 - 09 Feb 2013 23:04
#571670
red ignition switch goes to red tail light.
Blue wire from ignition switch goes to red/blue 10 amp fuse wire.
Orange/Green from ignition switch is your hazzard switch from bar control.
Last edit: 09 Feb 2013 23:04 by 4TheKZ1000.
  • odl666
09 Feb 2013 23:06 - 09 Feb 2013 23:16
#571673
Attachment NewWiringDiagrahm-2-9-13step2.png not found
Thank you, Please see the above update: I do not have hazards, blinkers, horn, or signals.
Brake light
Taillight
Headlight
Dyna Ignition
Dyna Shift Light
Dyna Coils
Ballistic 8 cell battery
4 prong switch (wanting to use for lights)
Kill Switch on Bars (2 wires)
1979 gs750e
Last edit: 09 Feb 2013 23:16 by odl666.
  • 4TheKZ1000
09 Feb 2013 23:38 - 09 Feb 2013 23:44
#571676
OK, Im going to get you to wire diagram.
Go to upper right of page. Find (Filebase) click on it
Goto 1978 and click on 1978. Go down list and find your model / bike and open.
You will see wiring diagram....open file and your in business.
Are you using factory right and left hand contols and head light?
Last edit: 09 Feb 2013 23:44 by 4TheKZ1000.
  • odl666
10 Feb 2013 01:19
#571690
Thank you! That is the wiring diagrahm I have been using. but it still feels like I am having issues. let me look it over again.
Thank you!!!
1979 gs750e
  • wireman
  • wireman's Avatar
10 Feb 2013 01:48
#571692
What is not working?need a general idea what the problem is B)
  • odl666
10 Feb 2013 02:31
#571693
Attachment NewWiringDiagrahm-2-10-13.png not found
I dont feel like it is getting proper spark, I couldnt see a blue arch when testing.
1979 gs750e
  • Old Man Rock
  • Old Man Rock's Avatar
10 Feb 2013 10:16 - 10 Feb 2013 10:31
#571721
Maybe this will help for bare minimum to start the engine/charging ckt...
TL 1 & 2 are for your other electrical needs for lights, turn signals, horn, tail/brake lights, indicator panel etc...
KZ-650-B1: 1977
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 10 Feb 2013 10:31 by Old Man Rock.
  • odl666
10 Feb 2013 12:30 - 10 Feb 2013 12:35
#571727
I do not have a starter, I am confused as to if I can hook the coil and ingition power to the white wires that are coming from the switch.
Also do I hook up the coils power wire before the fuse or after?
Please see attached.
1979 gs750e
Last edit: 10 Feb 2013 12:35 by odl666.
  • odl666
10 Feb 2013 12:37
#571728
1979 gs750e
  • odl666
10 Feb 2013 13:28
#571734
Attachment KZ650-B2C2-wiringdiagrahm-edited2-10-13.jpg not found
1979 gs750e
  • odl666
10 Feb 2013 13:46
#571736
I am confused because since I am NOT using a starter where do I get the power for coils?
The Starter relay appears to have a power wire which goes to the handle bar switches and then goes to coils.
1979 gs750e
