Help Please - Simple Wiring Diagrahm
Re: Help Please - Simple Wiring Diagrahm
10 Feb 2013 14:21Brown from ignition switch, through Engine Stop Switch (aka kill switch), to red/yellow wire providing switched batt+ to each coil primary terminal.
- odl666
10 Feb 2013 16:25Attachment KZ650-B2C2-wiringdiagrahm-edited2-10-13-revised.jpg not found
1978 kz 650b with gpz faq mods cams carbs polished and ported
1979 gs750e
1972 bsa lightning under construction
1979 gs750e
- donthaveakawman
- odl666
10 Feb 2013 17:03
Thank you for your help, I am going out to garage now. I hope I can start her tonight.
I have no instruments, only shift light.
1979 gs750e
1979 gs750e
- odl666
10 Feb 2013 17:28Attachment NewWiringDiagrahm-2-10-13.png not found
This is what I am going with....let me know what you think.
Question:
look at brake light, I have it wired to the red wire from the ignition.Same wire powers tail light.
Issue:
Seams the bike only runs when the key switch is turned to second position (First position everythign is off). lose brake lights at turn of final position.
Switch: Emgo 78 KZ 650b2 key switch.
1979 gs750e
1979 gs750e
- odl666
10 Feb 2013 17:29Attachment NewWiringDiagrahm.png not found
Question:
Issue:
1979 gs750e
1979 gs750e
- donthaveakawman
12 Feb 2013 21:22
so the power goes to the coils and the points ground them, is that what I am seeing here?
- odl666
Re: Update: Help Please - Simple Wiring Diagrahm
20 Feb 2013 21:42
The bike is all wired.
I only used the Brown (straight to Coils/shift light) and Red wire (Lights) from the ignition switch.
Issues:
The coils only work at half position on key switch.
Lights work only on full on position.
Wires left:
Green and Orange
Blue and Red
I want to be able to have the lights work on any position and the ignition to only work when Key is in full ON position.
Issues:
Wires left:
Green and Orange
Blue and Red
1979 gs750e
1979 gs750e
