Re Voltmeter and Charging
- Redwitch
15 Jan 2013 16:28
Just to say thanks for all your helpful suggestions. I borrowed a multimeter from work and followed the flow chart by Electrosport. I found the fault which was the 6 pin connector block coming from the rectifer/regulator. It was in bad shape on one side when I disconnected it, so i cut it off and rewired each wire with a new bullet connector. Connected the multimeter up to the battery again, started her up and hey presto I am now getting the correct voltage when I rev the engine. Took me all day Sunday as I have never done this before or used a multimeter (which is now on my shopping list to buy). Thing I have learnt is that it's really important to check through all your wiring and clean up connection. Thanks guys!
Original Message read
Hi there,
I think I have an issue with my charging system as my voltmeter needle stays on the 12 volt mark and does not go up with the engine revs. Is there an easy way to tell if it is my alternator at fault or my rectifier/regulator. Battery is brand new and was fully charged before fitting to the bike. Many thanks
Hi there,
Redwitch
1980 Kawasaki Kz750Ltd H1
1988 Honda CD250U
1988 Honda CD250U
- MFolks
Re: Re Voltmeter and Charging
15 Jan 2013 16:43
Here's good mutimeter instruction:
The Best Mutimeter Tutorial
Doing electrical work on a bike, is not black magic, just taking logical steps, and testing as you go through the troubleshooting charts.
15 Jan 2013 17:42 - 23 Jan 2013 14:33
There are plenty of choices in regards to a good multimeter. I've been using a VC97 digital unit for about a year (ebbaayyy ~$30). The robotroom tested a number of meters & it was rated as a good one to have.
Last edit: 23 Jan 2013 14:33 by martin_csr.
